Question about Kenmore 80754 Top Load Stacked Washer / Dryer
Kenmore washing machine
My water continues to fill even I turn my washing machine off. It was overflowing until I turned the water off by the nobs on the wall. can you please help me?
    New Friend:
Your selecta switch for the size of the load is at a midway point. Re-select the size of the load then restart but watch it for at least one cycle.
Posted on Oct 04, 2013
  • Mark lalancette Oct 04, 2013
  • 1,031 Answers
It looks like you have a water filler valve problem, with your washer emptied turn the water faucets back on and turn on the washer, if it starts filling turn your timer knob around several times, like you were hunting a cycle you wanted to use. This may make something dislodge from the valve.if blocked If not try the same thing with your water control knob. turning it from hot to cold and then to hot again......I hope these work.....check equally the hose and if that is your problem you may need a new water valve.
Posted on Aug 31, 2008
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
Cold/hot water is not coming when I turn on the washing machine
Try unplugging the machine and turn the dial all the way around once back to where you would normally start your wash do not pull out the nob to start the cycle until you have plugged the machine back in, this will sometimes reset the main controller (the control nob you turn) if this does not work chances are you need a new controll switch or timer as some people call it, hope this helps.
Sep 08, 2012 | Kenmore Washing Machines
What does error f27 mean? During the wash cycle the water runs in the machine continuously and the displays "F27." The only way to shut off the water is to turn off the water tap. Even when the machine...
"F27" is an Overflow Condition error. The following link explains how to troubleshoot:
http://www.fixya.com/support/r3608602-f27_error_code
This can be one of the more difficult error codes to diagnose because there are so many potential causes. Read through the information provided and try to eliminate the easy (and obvious) things first. If you have any questions, please let me know. I hope this help you.
HINT: One obvious symptom that helps narrow down a potential cause is the fact that the washer does not stop filling with water even when unplugged. More than likely, you have a defective water inlet valve that is causing this.
Feb 06, 2010 | Kenmore Elite 45986 Front Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer doesn't stop filling up with water
Almost went and bought a switch until I widened by search for "kenmore washer 80 series overflow" and came up with this:
http://www.fixya.com/support/t1206464-kenmore_80_series_overflow
Turns out that a couple weeks ago, I had a really unbalanced load that probably shook off the tubing. Anyhow, saved me a trip to the supply store AND cost. Thanks to the original poster!
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series washer
if the water was overflowing from the top of the tub it sounds like the pressure hose came loose. tilt the control panel back and you will prob see the hose that connects to the left side (where you adjust the water level) has come loose. cut about 1/4 inch off of it and re-connect it.
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Jul 17, 2007 | Kenmore 22442 Top Load Washer
Kenmore 80754 Top Load Stacked Washer / Dryer Logo
70 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
