Question about Car Audio & Video
Hi how to reset car alarm key fob. new batt put in on a laserline t108 lost paper work
emissionwiz
  • 77202 Answers
SOURCE: key fob will not undo
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
Posted on Oct 16, 2008
  • 4 Answers
SOURCE: cobra 7928 car alarm
hold both buttons down until led goes out. let go. led will stay on.
press large button twice.
actually
Posted on Oct 24, 2008
SOURCE: car alarm how to reset a cobra alarm after fitting a new batt.
i put a new battery on my car and now the alarm will not work
Posted on Oct 09, 2009
MNfisherman
  • 11896 Answers
SOURCE: lost original car alarm control... need to reset a new one...
programing a Nissan remote , is hidden secret by Nissan Dealers. As a Nissan Technician i will share it.
Just get in your vech , close all doors. Using your power lock switch , lock all doors. After doors are locked take your Ignition Key and insert it and remove it from ignition switch in a slow fashion , but consitant pace. (97 and earlyer are fast) When you see the hazzard lights flash, put key in ignition switch and turn to the On postion .. Do NOT CRANK or you will have to Start over .. After in the On postion .. Hit the Lock button on remote... Hazzard lights should flash..( note..you have to reprogram all remotes when adding a new one , if you don't your old remotes will not work ) If your doing just the one , turn igntion switch off and unlock door and get out and try it. If you are doing more than one. While still in Vech with Key on . After you hit the Lock button on Remote and hazzard light flashed .. with key still on .. use master lock switch unlock doors and relock and then hit Second Remote, Lights should flash again , repeat if adding a 3rd remote.. after done just turn key off and unlock door and get out and try.
Posted on Oct 29, 2009
  • 15 Answers
SOURCE: transponder chip in key fob
This will all depend upon what country you are in, and if the vehicle even has the need for the chip to be programmed at all.
When you put a proper key in the ignition, is there a antitheft logo that cycles with the other indicators?
VW antitheft indicator in the USA often looks like a car with a key under it
In the USA, thought the keys have a MEGAMOS RFID chip, no system was active until 2000, and on some models, not until 2002
A system requires a VIRGIN chip. Once the chip is programmed to a car, the chip is locked to that car. Some new software can unlock and refresh some chips, but not 100%
I had a client come in TODAY with a 2003 Passat, and an EBAY flip key.... I wasted a half hour programming time..... but I carry the lower half of remote, which hold the blade and the chip, so was able to fix client up, when EBAY failed.
If this was helpful, please post a nice review for City Lock in Boulder Colorado listings on Google Maps, Yahoo etc. This listing will link you to my website as well. On my website are resources for finding a legitimate locksmith near you. Be sure you are hiring a REAL locksmith!
Thank You
Jeff
Posted on Jul 24, 2010
Replace the battery and it wont start
When the anti theft system was created,the dealers forgot to tell the new car buyers about how much the fob matters to the vehicle,without it,owners are stuck,your anti theft device is activated,you need to lock and unlock your doors a couple times with the key fob,not the key,and then you need to put the key in the ignition and start it,if you dont have your key fob,call your car dealer to get a new one,they are programmed for each car only,you cannot bypass it.if you lost your fob or never had it,whatever,you need to have the exact fob that came with that car from the factory,the key and fob have a chip in them that only go to that certain car,if you do not have it,then you need to buy a new one from the dealer or ebay and then you need to contact your dealer about programming the fob to your car,you might not have to have it towed if they have the documents from the car,the only other way is to get a junk car,with the steering column,key,fob and all computer boxes and door locks and switch them,(i just did that with a 98 dodge dakota,and it works.)
Jul 23, 2015 | 2004 Hummer H2 SUV
My honda blackbird XX 2004 factory alarm will not respond to the key fob control. New batt in fob. New batt on bike after standing one year
Useful forum here
http://www.cbrxx.com/engine-airbox-exhaust-fuel-delivery/17742-noobie-97-bbird-not-starting-alarm-problems-data-tool-unable-unwilling-help.html
Jul 17, 2015 | 2004 Honda CBR 1100 XX Super blackbird
How do i reprogram 1996 toyota celica key fob
http://www.toyotaownersclub.com/forums/index.php?showtopic=50803
May 15, 2010 | 1996 Toyota Celica
Alarm went off and key fob quit working
start the car. if that dose not work remove ground form battery then after it stops put ground back on that will reset the alarm.
Jan 28, 2010 | 2009 Dodge Grand Caravan
Toyota avensis 1998 cdx key fob can't activate immobiliser
Not a solution just another problem...Lost my car fob key, have a replacement key no circuit. As I open door, sets off immobiliser like above for20 mins. I had someone look under the glove compartment but that got me no joy. How can I (non techy) resolve this so I can drive my baby home...Vreg Avensis1.8 model?
many thanks
Aug 31, 2009 | 1998 Toyota Avalon
My key fob wont lock or unlock and set the alarm anymore. I put a new battery in and everything!! HELP!
Sounds like you lost program, or a bad key fob. Either way, check with the Honda dealer.
Jul 14, 2009 | 2004 Honda Pilot
Car alarm how to reset a cobra alarm after fitting a new batt.
Dec 16, 2008 | 2006 Mitsubishi Colt
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
