Something seems to have taken over my keyboard. It won't let me select b or 5. Please help.
    Scholar:
  • 71 Answers
Is is a usb or ps/2? Soda, dirt, crumbs, and sweat can jamb up contacts under your keys. Have you tried another keyboard?
James Mac
Posted on Aug 31, 2008
The symbols on my Dell L100 Keyboard do not work consistently in MS Word. Today I cannot get the quotation marks to work. The other day the question mark didn't work. It seems to only effect the ones...
It seems like you may have a strange language setting for your keyboard. Try going to Control Panel, and selecting language. It should look similar to this: snowyrat_1.jpg
There should be a tab labled something to the effect of "Change Keyboards or Other Input Methods." Select that, and then select "Change Keyboards" You'll get a menu that looks something like this: snowyrat.png
Select "Add" and scroll down to "English (United States)" Select "US(Default)" and click ok. Select US as your keyboard, and the problem should be fixed. If that's not the problem, then it may be a setting in MS Word. Hope this helps!
Mar 28, 2011 | Dell Latitude 100L Keyboard
I am having trouble getting a 1994 Land Rover defernder 90 into reverse please help
The gears are selected by using one shaft with 3 forks. 1 and 2, 3 and 4 and 5 and reverse. When you move the gearstick to the left for 1 and 2, a notched ( that's all I can think to call it)circle around the shaft turns and engages the fork. When you want 3 and 4 another engages the fork, the same with 5 and reverse.
If the others are selecting, then something has either slipped or is jamming the stick.
If 5 engages, then it should go back to reverse, the same as if 3 engages, it should go back to 4th. If 1 and 2 engage, it seems like something is blocking the bottom of the stick from physically moving. Take the gearstick out first and see if something like the reverse switch has broken away.
Jan 01, 2011 | 1997 Land Rover Defender 90
I could not able to select the tones.It needs to be reset to the factory level.Please help me to reset the Keyboard to the original status.?
Sometimes companies use the same sequence for all their synths...
Here is one to try:
How do you reset casio keyboard lk-60?
This is how. 'Turn keyboard of for 5 seconds then turn it bak on and play"e-flat,g-flat,e-flat,b-flat,g-flat,e-flat,g-flat" then turn keyboard of and unplug and wait 5 minutes then plug back in in,...
Note: It is NOT clear if you need to hold the notes down as you play them or press and release.
Here is another for Casio:
From the FILE menu, select INITIALIZE to select the sub menu. Select the SYSTEM option to return the keyboard to its factory settings. Keep in mind that this operation will delete anything that is stored in the keyboard memory. When you see the InitSys? on the screen, select YES. I hope this helps......
I could not find anything specific to the 810.
If these don't work, then the way to reload is via the MIDI port which will accept Sysex commands and data. You can probably find a data dump online for this at the Casio site..
You will of course need to have a MIDI port on your PC.
Sep 16, 2010 | Casio CTK810 61 Key Keyboard
Adobe reader has taken my computer over
If you are useing windows this will help you make any program run with your desied aplication ie.word,open office.it seems like adobe was installed to open any program it could this is normaly the defalt seting for aplications.>>rigth click on the document you want to open and select OPEN WITH> your aplication you want may be here in the list or for the first time select brows programs to find the desied one. select apply
Jun 03, 2010 | Lanier UNKNOWN
Logitech cordless keyboard not working properly - keys stick or are delayed
Did you spill something on it or is food lodged in unit if so take apart clean.
Fresh batteries would be good start.
Feb 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Keys Confused on logitech ultra-flat keyboard
You have to change the KB language to US-English. It seems that you got the European layout set up currently.
Go to Control Panel and select "regional & language settings". In the tab marked 'regional options', select "English (United States)" from the drop down menu. If that is already the selected option, then choose "English (United Kingdom)" instead. That should solve the issue.
Cheers!
IrishDruid
Jun 23, 2009 | Logitech Ultra-Flat Keyboard
Desktop items access denied Please Help Me!!!!
If you've taken ownership of the folders, you should be able to access the Security tab and assign yourself full permissions to the folder.
If you don't see the Security tab, go to Folder Options in Control Panel, select the View tab, then in the list box scroll to the bottom and de-select Simple File Sharing.
Hope this helps!
May 18, 2009 | Microsoft Windows XP Professional for PC
Logitech easycall mouse works but the keyboard will not
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
Jan 30, 2009 | Logitech EasyCall Desktop Retail Keyboard,...
Keyboard stoppped working
Mar 14, 2008 | Logitech EasyCall Desktop 967689-0403...
Keyboarb
hi, its a very common issue, the keyboard itself needs to be taken care off,try removing it and clean the contacts/connectors, check if any key is getting stuck? let me know
Dec 03, 2007 | Panasonic Toughbook 51 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
