Question about Dell Audio Players & Recorders
No sound with anything
I have dell speakers it says Rev AOO and i went to control panel and device manager and tried but nothing's coming out. I need the driver i believe but don't know which one i need plz help.
    Problem Solver:
  • 11 Answers
Head over to support.dell.com
Click on product support.  Either enter your service tag, or your model number and it will take you to some basic information on your PC.
Click on drivers and downloads, locate your audio driver, download and install.
If that doesn't fix it, try the speakers on another computer to ensure they're working properly.  Also, if possible try a set of known good speakers and see if that works on the computer.  This will help you figure out which piece of the puzzle isn't working.
Posted on Aug 31, 2008
My Dell twin speakers suddenly not working today Monday 5.9.11. Were working OK about 3 to 4 days ago. Have not disconnected anything and all plugs seem to be in order. First time this has happened in...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 05, 2011 | Dell A215 Computer Speakers
Brand new out of the box Dell 560 set everything up and plugged in the speakers to the USB and the jack in the back and nothing no sound. the speakers are on, but the machine says no device detected. ...
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 11, 2011 | Dell Audio Players & Recorders
Dell A425 2 speakers not working. Computer setup was moved across a room. Everything was reconnected exactly as before; all connections and settings have been checked and re-checked. Nothing is muted. It...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
don
Feb 14, 2011 | Dell ADA425 2 Speakers
Computer sound is off so I need your help
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 15, 2010 | Dell Computers & Internet
I have no sound on you tube its driving me crazy! I need easy fix sound instructions
you might want to try the large hammer approach (joke)
hope this helps
No sounds, no speaker icon in the tray
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 21, 2010 | Intel ASUS P4S800 Motherboard REV. 2.01...
My computer speakers won't work. There is no sound. They will turn on, but no sound is coming out of either speaker. I tried all the windows help but nothing worked.
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 06, 2010 | Gateway G-MAX2000 2-Piece Multimedia...
No Sound from speaker or the computer. \r\n
well if no sound is coming out then first you just check wire connection properly. and when everything is ok then just check for the driver .. sound driver is properly installed or not.. you can do this in control panel then device manager. now if you see driver is not installed then go online search driver .. for your sound card,, thatsit.. your problem will get solved .. :D
Jun 03, 2010 | Dell Inspiron 530 Desktop Computer
I have a dell computer and the speakers are attacked to it but i cant hear anything. i checked if the cables were in the right place but they are and i still cant hear anything. i went to control panel and...
If everything is grayed out in the audio devices property in the control panel, that means there's a problem with your audio driver, first step I would take is to reboot your machine, hopefully it will come back.
If that fails, most Dell computers come with a Application CD, put the CD in the CD rom drive and have it reload the audio drivers back in.
Also make sure your speakers are plugged into the green port on back of your computer
Feb 17, 2010 | Dell Audio Players & Recorders
DELL 62YVH - REV:AOO
i need he driver for the dell 62yvh.rev.aoo
Aug 03, 2009 | Intel Motherboard
258 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
