Question about Kenmore Dishwashers
Water drainage I have a old kenmore model 363.14031000 serial HZ313550R. There is water on the bottom of the dishwasher that won't drain. This is our first time running it since we moved in. Is this natural? The water is below the sprayer arm or whatever you call it. If this is not natural what can I do to fix it?
  • 55 Answers
  1. Some units hold water in the bottom so the seal in the bottom will not dry out. I suggeat you contact Sears. JOHN-LA.
Posted on Sep 01, 2008
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Have a rental property with F&P two draw dishwasher aprox five years old. Apparently bottom draw is holding water - what do you think?
Could be many reasons for the bottom drawer to hold water.
It could be leaky top drawer causing water to collect in the bottom drawer. Check if water collects when top drawer is running.
It could be blockage in the bottom drawer drainage which can be fixed by cleaning the filter plate and the drain sump. If the drain pump is not running during drain cycle then you will have to replace the drain pump motor.
Aug 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher will no longer drain completely
The pump is bad and needs to be replaced. The pump is not pumping out all the water from the system
May 05, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Kenmore elite dishwasher, less than 1 yr old. Wont drain. I have pressed ''Drain'' on the keypad, motor/pump runs but no drainage. If blocked, where? Can I clear it without having to dismantle and remove...
take a shop vac and attach it to the ond of the drain hose to remove the water and if you are checking the drain pump then it has to be pulled out from under the cabinet.
if the unit is less than a year old just set it up for service it will not cost you anything
Apr 10, 2010 | Dishwashers
Sink dishwater intrusion
Hello- Find drain hose from dishwasher under sink. Should have gooseneck ~ in hose run to keep water from getting back into dwshr. Does full sink drained all at once push water into tub? Sometimes stuff not disposalled yet blocks drainage. Older motors can tend to become weak with age, not pumping as much water out of tub as it used to.Anyway- Hope this helps- ED
Mar 01, 2010 | GE Dishwashers
Kenmore 665.16705891 dishwasher
First make sure it will run by hitting "cancel' or turning the timer to drain cycle.What is the Model& Serial number???I'll be happy to get this solved for you. :)
May 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
126 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
