Question about Sony Cyber-Shot DSC-F707 Digital Camera
Undo White Balance Sony F707
I am in the scenario where I've just returned from the Grand Canyon and discovered that all my photography (with my old Sony F707) was done with the white balance key mistakenly depressed on the barrel. As a result most of the outdoor shots have a bluish-greenish tinge to them. I'm desperate for suggestions on how to correct this by post-processing the images and appreciate any advice and pointers ! Thanks in advance
    Master:
  • 551 Answers
1) Image/Adjustments/Levels, click grey (middle) eyedropper on light in foreground of picture. 2) Image/Adjustments/Brightness and Contrast, increate brightness 3-4 points 3) Image/Adjustments/Hue and Saturation, drop the saturation (for all colors, RGB) down 3-4 points.
Posted on Sep 12, 2005
    Master:
  • 551 Answers
If you have Photoshop: Layer>New adjustment Layer>Levels Use the middle eyedropper tool and click on something in your photo that should be gray/dark gray. Or: Use the white eyedropper (far right eye dropper) and click on something in the photo that you know is (or should be) white. You can try the gray first, then the white.
O flesh da minha camera sony dsc f707 nao esta funcionando gostaria de saber o problema sera que tem alguma configuracao
hi sony f707 and f717 have very common flash fpc(flexible printed circuit) torn due to flash defuse unit up/down many time. it just need replacement. Thanks and best regard!
May 24, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
Whitebalanc; red cast over pictures
Greetings...
The red or orange cast comes from a warm light source since you have the auto white blance off...
Got to your menu and turn the auto white blance back on and then try taking the same picture under the same lighting and see if that corrects your problem...
Ed
Apr 08, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony F707 LCD/VF green tint
I tried the suggestion by sony and it worked! They said to hold the on-off buttom for 30 seconds.
Nov 16, 2007 | Sony Cyber-Shot DSC-F707 Digital Camera
Getting accurate color
1) Turn the Mode Dial to MANUAL MODE (Red camera icon with an "M") 2) Use the Arrow Down on the ENTER Button to select W/B (White Balance) 3) Press the center on the ENTER Button to select and adjust W/B (White Balance) 4) Use the Arrow Right (once), then Press and Hold the Arrow Down. Note: Continue to Press and Hold the Arrow Down. There will be a pause as you reach the bottom of the common preset conditions. Then a new "hidden" option will appear. 5) Once PRE SET appears, Press the center of the ENTER Button to select it. 6) A Special screen will appear. Point the camera direct at something WHITE, like a piece of paper, a white wall or a white shirt. Regardless of the lighting conditions, the camera will accept this "white object" as the new starting point "base of reference" or "True White". 7) Press the Shutter Button to program the new "True White" setting. 8) Press the center of the ENTER Button to accept and continue photography. These new settings will be saved as PRE SET True White conditions in Manual Photography Mode until you change the settings with another selection. This will not "go away" when the camera is turned off. These settings do not impact Auto Photography Mode.
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
DSC-F707 viewfinder black
This same thing happend to me awhile back. Camera seem to be dead for several weeks until one day I tried turning on and then off the night vision. The was the usual click inside the camera and all was well after that. I still use the camera.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
F707 won't power up
Hi Rick, have you fixed your 707 by now or disposed? As I'm facing the power problem with my F707 i came across your message. Mine, I have the problem with ON & OFF switch I guess. I removed the battery and did a reset it turns on.. Shuhaib, India
F707 slow to "boot up"
I haven't had any such problems on mine. Have you tried swithching memory cards or re-formatting. With some other cameras such problems are attributable to the memory card.
Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Limited setting for White Balance.
Hi: So you bought the camera but didn't make a good choise :) Yeap, the "four only options" in the Sony F55 in the White Balance Function are what you said. You have to have that in attention when buying a Digital Camera. About the White Balance > Hold, the intention is to adjust the white balance acording to an object. After you select the option, to use it you just have to point the camera to the object, press half off the shutter button to focus, then you chose the angle and press the rest of the shutter button. On the other cameras those options improve the quality of the skin tones and colors of your subjects reduzing color temperature. Regards
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
176 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
