Question about Bose Wave Music System CD Shelf System
External FM antenna
The waveradio I own has a 1/8" 75 Ohm female connector on teh back panel. The external antenna I purchased (a TERK product) has a typical 75 Ohm coaxial male connector.
  • Anonymous Dec 06, 2008
    We have the same problem - does Bose really not offer an antenna for its own players?
    Tony Anemone
  • Anonymous Dec 29, 2008
    I hsve the same problem.... did anyone find a solotion for this fm antenna problem...
The fix for the problem is simply go to Radioshack and purchase their part number 278-267 which is an "F" jack to 1/8" Male Plug. The cost is $6.09. This should solve your problem. The 75-Ohm antenna plug can now be screwed or connected to the "F" connector.
Posted on Mar 11, 2010
Bose Customer Service (800) 444-2673 can provide the correct antenna for the unit.
Posted on Dec 23, 2008
How do we set up the tv to pick up air channels with the indoor amplified antenna?
Terk FDTV2A HDTV Indoor Antenna Unboxing Setup Test Part 1
double check your TV is set to the correct input before scanning.
the link above shows installation
press the helpful button
Jan 22, 2016 | Sharp LC52E77UN 52 in TV
Fm aerial connection ?
Both of my Marantz receivers use a 75 ohm coax input. The receivers included a single wire antenna that simply plugs in. The plug is suitable for coax cable going to an external antenna. You can also get a small 75 to 300 ohm transformer that will allow you to use a dipole or other common indoor FM antenna.
Feb 11, 2015 | Marantz Audio Players & Recorders
Grundig Satellit 800 external antenna configurations
It looks like you have a real scientific project. It sounds fascinating and it seems to go well beyond the mere enjoyment of a simple Short Wave Radio. My suggestion: Put your hypotheses/questions to the test and you will form an informed opinion.
Apr 08, 2013 | Grundig Satellit 800 AM/FM/SW Radio
What kind of wire or cable should i use between my receiver and amplified fm antenna?
Your Terk antenna has a round F connector for 75 ohm coax cable. Unless your receiver is really old, it has an F connector for the antennaas well
Feb 16, 2013 | Terk Televison & Video
My t.v. has volume issues. Volume between channels and also within one channel (while viewing) not even. Happened when connected to basic cable and now when connected to just an antenna for reception. ...
it is fixable the sound may depend upon the channels also but the antenne might not beeing catching signals properly so by changing the face of antenna u can remove this problem
Mar 31, 2011 | Panasonic TC-32LX85 LCD TV
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
I am having very poor FM reception with my Bose Radio wave system. Is there an external antenna that can be attached?
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Dec 25, 2010 | Bose Wave Radio
Need to know how to go cable free. Have TERK digital antenna
Shouldn't do, just connect the antennas into the Belling-Lee TV antenna socket at rear of set, tune channels. If you antenna won't fit, you may need an "F" connector to "Belling-Lee" converter plug. You will need an "Ordinary" Yagi VHF/UHF antenna installed though. Is that what that digital one is?
Feb 14, 2010 | Hitachi 51G500 51" Rear Projection...
Bose Wave Music System CD Shelf System Logo
2,018 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
