Question about JVC HD-56G886 56" Rear Projection HDTV
JVC TV Front panel power button blinking
HI I DONT HAVE NO KNOWLEDGE WITH ELECTRONICS AND MY HUSBAND IS DEPLOYED ABROAD. I TURNED MY TV ON THIS MORNING ANG IT WAS WORKING FOR A FEW MINUTES, THEN THE TV JUST WENT BLANK AND THE FRONT PANEL POWER BUTTON KEPT BLINKING. I UNPLUGGED THE TV OFF THE WALL AND WAITED FOR ABOUT 30 MINUTES, SCREEN WAS BLACK AND THE POWER LIGHT JUST BLINKING.
I HAVE NO IDEA WHAT THE MODEL OF THE TV IS, ITS 61 INCHES AND ITS BASICALLY SCREWED IN PLACE, CANT MOVE IT AT ALL.
DO YOU THINK THIS WOULD BE ALAMP PROBLEM.NEVER HAD PROBLEMS WITH THIS TV EVER, WE HAD IT FOR OVER A YEAR.
I TRIED CALLING A SERVICE TECH BUT DUE TO THE HOLIDAY WEEKEND NO ONE IS AVAILABLE.
PLEASE HELP!!!!
ARMY WIFE
  • dehn Dec 24, 2008
    I have the exact same issue with mine, assuming it is the bulb. If so I will post back.
  • JVC Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 21, 2009
Coby 26" loses sound after a few minutes, any guess why?
Electronics can fail after they warm up. When they cool down again they start working again. The electronics need replacing, on this TV its cheaper to replace the TV.
Dec 15, 2013 | Coby TF-TV2617 26 in. LCD TV
I dont know the email address of ted failon, i want to send a letter with him regarding his program failon ngayon, thank you
To Mr.Ted Failon,
Isa po aq ofw at may problema sa year of birth ng husband ko,gusto ko lang itanong kung tlg bang kinakailangang dumaaan p s trial court,mgkaroon p ng hearing at ipublish ng 3 beses bgo mbago ang ang year of birth ng husband ko s aming marriage contract at ayon sa knila ang pagaayos nito at umaabot sa 40k to 50k? samantalang ang baptismal at birthcertificate nman ay tama ung sa marriage contract lng nman mali>Ano po bang aksyon ang pede nyo pede maitulong s aken pra mpbilis ito?maraming salamat po Ma Ana Perez of Vancouver
Dec 04, 2010 | Computers & Internet
I have a SVA VR 30 LCD TV that for some reason stopped working. It was work last night-the little on/off light was lit when I turned it off. This morning it wasn't and my husband changed the power strip,...
The power supply may have failed due to bad DC filter caps which you can easily look at them for sign of elaking/bulging top first.
Post back what you see inside so we can guide you further.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Aug 13, 2010 | SVA-USA VR30 30 in. HD-Ready LCD...
TV continues to turn off on its on
You will have to look for cold solder joints in the power supply board first and check the voltages.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Jul 09, 2010 | Akai LCT3201TD 32 in. LCD Television
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
Polaroid 2700 hdtv power supply
The only place I have been able to find the power supply or main board for this is shopjimmy.com or Ebay but even there I can find none.Tell your husband to check for puffy capacitors in the power supply.This is a very common problem with these power supplys.
Jan 15, 2009 | Polaroid FLM-2632 Television
Mitsubishi WT42313 @ 4 YRS OLD
In my opinion, you need TV-Technician to rectify the tv problem.
In case you want to fix it yourself, you should get its service manaul or schematics and enough knowledge of Electronics because TV has high voltage risk inside.
Aug 18, 2008 | Mitsubishi WT-42315 42" TV
Patay sinde
Your concern is that the TV turns itself off. This could probably be due to any of several possibilities:
1. cold solder or loose connection, may maluwag na koneksyon sa loob o mayroong hilaw na hinang. Kailangan lamang itong painitan ng soldering iron upang muling manumbalik ang kinang at tamang pagkakapit. May mga pagkakataon na maaring maluwag din ang ACplug sa outlet;
2. heat induced - may pyesa na nag-iinit at tumitigil sa pag-andar pag mainit na. Kadalas ay mga capacitor, transistor or regulator;
3. low supply of the AC mains - mababa ang kuryente, maaring ito ma-check sa pamamagitan ng isang Voltmeter. Kung mababa nga, maaring gumamit ng voltage regulator kagaya ng sa mga computer;
4. timer - may mga pagkakataon na mayroong timer kaya kusang nag-switch off anf TV makalipas ang takdang oras;
Of course repairs would involve knowledge and familiarity with electronics circuitry and components, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 25, 2008 | Sharp 25N-M100 25" TV
RCA M134C 27V412T
hi there, you can try the front panel switch to unlock it or to turn it on. if still same problem you do have an electronic parts trouble with your unit. check the power supply section of your tv and test some electronic parts. ty
Dec 24, 2007 | JVC AV-27D302 27" TV
JVC HD-56G886 56" Rear Projection HDTV Logo
1,770 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
