Binoculars
Problem for Binoculars
Generic problem for all Binoculars
Binocular repair
By Lynly on Aug 31, 2008
My husband dropped my minolta standard XL 12X50 wide angle binoculars off our pier into salt water. He failed to retrieve them for several hours. It is obvious that water has gotten inside the binoculars. Can they be successfully salvaged and restored?
Same Problem
Oct 26, 2008
-   Someone in my household dropped my Minolta Binoculars and now they won't focus. They are Model MK 1331551. Please advise where I can locate someone to repair them.
Curt Schreck
132 Sudderth Rd
Hoquiam Wa 98550
360-987-2549
blakesleejm@hotmail.com-   blakesleejm
Best Solution
posted on Aug 01, 2009
Very Helpful)
Zeiss Man
Rank: Guru
Rating: 93%, 31 votes
Yes they can be but need to be completely taken apart and cleaned. The salt will corrode any metal parts such as screws etc. The water may have left a coating on the internal glass services. Any impurities in the water may cause fungus to grow. Professionally done this will cost a tidy sum so a quote would be best. The warranty wouldn't cover water immersion if they are not meant to be waterproof. You could ask but Minolta no longer make binoculars and have forwarded on their servicing here is the web address
http://ca.konicaminolta.com/support/contact/binoculars/
You may find that for the cost of repair you can purchase a replacement set. Minolta binoculars are heavily discounted now. For sentimental reasons I have paid more than a binocular is worth to have it repaired.
If you are going to buy a new set and still want to try at home....BE ADVISED this may RUIN the alignment and you should ONLY DO IT if you are going to replace them and DO NOT CARE if they end up in the rubbish bin. THIS IS A LAST RESORT THROW AWAY FIX.
Try and unscrew the objective barrels, the ones with the large lens. If they come off you should have access to the inside. If they don't unscrew easily stop. You will damage them. Flush them out with clean water and let them dry naturally. Avoid letting them dry where dust can enter the inside. This may clear the salt from inside them, Depends on how long since they were dropped into the water. The salt may have caused damage to the glass coatings. When dry, screw the barrels back on. You may end up with a double image. This may be able to be corrected by loosening or tightening the barrels. THIS IS A HACK FIX AND YOU SHOULD ONLY DO IT IF THE COST TO REPAIR IS TOO EXPENSIVE AND YOU ARE GOING TO REPLACE THEM.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Binoculars
Questions and Unsolved Problems for Binoculars
Answer
I have this camera to be onest I lost the chgarger so wont by pentax charger d-bc42 for this camera... (More)
Answer
i need driver for suntec pc camera model no.szyht
Answer
I am using parts from a pair of 15x70 binoculars to attempt to create right angle binocular... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Binoculars:
Top Binoculars Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Binoculars Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
