Question about Compaq Inkjet Ij300 Printer
My Compaq IJ300 printer (which has a new inkjet cartridge) will not print when I attempt to print a page. I have the computer and Compaq IJ300 printer on. However, the white flexible ribbon that attaches to the metal "track" (which holds the the injet cartridge) will then jam and make a low pitched noise. Immediately afterwards, the two green lights on the top of the Compaq IJ300 printer will flash continuously. I have tried to reboot the system. I have turned the Compaq IJ300 printer off then on again. The Compaq IJ300 printer will not print whatsoever. Please advise.
SOURCE:
DJYar
  • 41 Answers
SOURCE: Printing
Sadly, Compaq printers (rebranded low-end Lexmarks, the X11 in your case) were not robust at all. Since they were originally created to be a free pack-in for new home PC's, they were not really meant to be used for more than a year or so. It sounds like there is some build up around the jet area, this build up will smudge around when printing. You can try to clean it out with a few cotton swabs although if you aren't careful, some cotton fibers might join in the mess. Another trick I have done in the past is run a piece of cardstock through the printer a few times. Sometimes the extra thick paper will help scrape off excess inks.
Posted on Aug 23, 2007
Tamms_2
SOURCE: Black cartridges won't print. Color cartridge works.
Why dont you go to the store that you bought the printer from and ask one of there people there fix the problem..
Posted on Dec 28, 2007
SOURCE: Printing Problems
If it is a black cartridge but printer was added indicating a color cartridge - believe it gives the 3 lines. Perform cartridge management and specify a black cartridge.
Posted on Jan 06, 2008
SOURCE: compaq ij300
cartridge setting was on color changed that to black and problem was fixed
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: I just got a brand
check your preferences
Posted on Jan 08, 2009
Printer ceased printing,renewed cartridge,followed all recommended processes.but it produces blank return.tried on several computers,can it be a head problem? I need to print floppy disc content Any advice...
The first 2 things I would do are check that you are using genuine Canon cartridges and run a head clean on the printer.
Head cleaning options are usually available under printing preferences for the device.
Mar 21, 2014 | Compaq Inkjet Ij300 Printer
How do you connect a compaq ij300 printer with no cd?
I presume you mean install and not connect,.... Go to Compaq and look under downloads and support, and get new install program for your printer and OS.
Mar 06, 2011 | Compaq Inkjet Ij300 Printer
The print size changed from regular sized to very small. What can I do?
try printing a test page from the properties menu of the printer and see what happens.If it's alright thenit;s what you printed that cause the reduction
Oct 07, 2009 | Compaq Inkjet Ij300 Printer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Compaq Ij300 Power Adapter
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Jul 15, 2008 | Compaq Inkjet Ij300 Printer
Compaq ij300
Jun 22, 2008 | Compaq Inkjet Ij300 Printer
Dec 28, 2007 | Compaq Inkjet Ij300 Printer
Printing
Aug 23, 2007 | Compaq Inkjet Ij300 Printer
Printing Problems
My compaq ij300 was doing the same thing. I removed the cartridge, took a kleenex and wiped the back of the cartridge until it was completely dry and shiny looking...until no more ink would come off on the kleenex. Replaced the cartridge and aligned it using the printing software. I didn't use the test page, just typed a one-line document and hit Print. That took care of the problem.
Dec 20, 2006 | Compaq Inkjet Ij300 Printer
Printer prints each line 3 times
There are a number of possible reasons for the problem you are experiencing: 1. The printer head might need alignment - use the printer?s software to align the heads 2. Does the problem occur with different cartridges? Try with an old cartridge before opening a new one. 3. If the ink is smeared you might want to clean the printer - make sure no hair or dust balls inside.
Aug 23, 2006 | Compaq Inkjet Ij300 Printer
Compaq Inkjet Ij300 Printer Logo
91 people viewed this question
Top Compaq Office Equipment & Supplies Experts
Ekse
Damen Wong
Damen Wong
Thomas F. Schneider
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
