Question about RIM BlackBerry Pearl 8100
How to switch off the green and red LED ?
My new balckberry pearl works great. but two days ago the LED red light on top of the screen started to flash. then it changed to green and i dont know how to turn it off.
I am afraid it is eating off my battery.
My sons and wife also use the blackberry pearl 8100 but they have no problem with the blinking LED. I live in new york. can some guru or wiz help me please.
Thanking you,
Mathew Kall
e n a p r a v u k a l @ h o t m a i l . c o m
My wife and I both have Pearl's. I found that the problem on both of them was caused by Color Pearl, an application that allows you to change the color of the Pearl's trackball. It was not a problem until upgrading the Blackberry software to v 4.5. I tried rebooting, removing the battery, etc. The light always came back on after an alert. Removing the application ColorPearl did the trick. Just go to Options>Advanced Options>Applications and delete ColorPearl. Hope this helps someone.
Posted on Mar 21, 2009
options - display - screen display - "LED coverage indicator" if the box is checked then you get green light blinking. If not, then no light unless you have blue light indicating blue tooth is turned on like for head set or red for messages.
This is the solution on a 9700 assuming that I am addressing the correct problem. Likely similar options hiding on your 8100 ...
Posted on Jun 26, 2012
My device a red blinking light with a dark screen.
The red blinking light can mean a couple of things. First, It could mean that you have a message. If that is not the case, you caould have on the 'LED Coverage Indicator'. The LED Coverage Indicator tells you by having the top light flash eather Green or Red depending on coverage. If you are in a place that has good coverage it wil flash Green but if you have little or no coverage the LED will flash Red. To check if you have this setting enabled, first go to "OPTIONS" on the phone in the full menu. Once there, go to "SCREEN AND KEYBOARD". Click on 'SCREEN AND KEYBOARD" and scroll down will you see the option that says "LED COVERAGE INDICATOR". Click on that and switch it to OFF if it is not already there. Then click the back bottton and click SAVE. That should work. If it doesnt, I would call your phone carrier and ask them.
Feb 19, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Have a dark screen but apparently BB is working as I get vibration (but no ring) when either a call or text is coming in. Tried battery reseating and sim card reseating. Checked battery and have good 3.7v...
i bought new phone today it balckberry 8120 pearl and i cant turn it on i recharge the battery like 5 hour and all i can see is a flesh red light that al
Apr 02, 2010 | RIM BlackBerry Pearl 8100
Black Berry Pearl Black Screen with alternate flashing lights
Jun 28, 2009 | RIM BlackBerry Pearl 8100
Green light flashing on blackberry pearl
This just means that the phone has coverage. under options and then screen/keyboard, you cna turn it off by where it says LED coverage indicator.
Apr 10, 2009 | RIM BlackBerry Pearl 8100
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
RIM BlackBerry  Pearl  8100 Logo
283 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
