Question about Intel Motherboard
Error loading I have the same loading problem that includes mp3plugin.dll do i have to dump my hard drive to get rid of this ?
  • Roberta Smith
    Roberta Smith May 11, 2010
    what is that file in relation to (program) and have you recently uninstalled it ?
    Robert
  • 797 Answers
Hi:
Don't assume I can read the thread post before you are relating to...I have no way to do that.
What you need to do is to explain your problem in the post you are putting up. Do not relate to something and saying you have the same problem...
I have no idea which problem, and have no way to see what it is.
take care,
Posted on Sep 03, 2008
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
  1. Restart the PC. The hal.dll error could be a fluke.
  2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
    Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
  3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
  4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
    Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
C:\PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL -- PLS HELP!! :(
Start
Control Panel
Add/Remove Programs
Select and remove the "My Web" application.
Restart your computer.
Jun 04, 2009 | Intel Motherboard
Run dll error loading 1`mywebs 3.bin`mp3plugin
Download spybot search and destroy from here:
http://www.safer-networking.org/index2.html
Install and run it.  Sound to me like you orphan files from spyware.
Mar 06, 2009 | Intel Motherboard
Dll MISSING:
reinstall drivers and utilities directly thru dos environment
Jan 25, 2009 | Intel Motherboard
Mp3plugin.dll missing
hi,
http://www.fix-all-dll-errors.com/mp3plugin.dll/
u can go to this site...this site helps u in case of ur missing dll.... helped in my case :)
Oct 26, 2008 | Computers & Internet
After windows xp loads on startup I get an error message it says: C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL I cannot find the file that might be corropted
Try this:
Click Start>Run>type "msconfig", then click the tab start-up and boot.ini, and see if you can find the C:PROGRA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL being loaded on start up, uncheck it then click okay and then restart the computer
Aug 23, 2008 | Computers & Internet
C:PROGA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
I am running XP. I went to RUN - MSCONFIG, then go to START tab. You will find an entry for this DLL. Uncheck to box, choose APPLY, and restart your PC, the nagging pop up on restart should be gone.
Aug 01, 2008 | Computers & Internet
Missing m3plugin.dll
hi,
http://www.fix-all-dll-errors.com/m3plugin.dll/
This site will definitely help u...
as I registered few dll's from this site...worked in my case :)
Jul 01, 2008 | Intel Motherboard
Error
Both of you need to do a virus scan. I prefer avast.com home edition. It is free and very powerful as well as easy to use. Then get ahold of an anti spyware program Webroot is an option. I prefer spybot search and destroy. It is also free. In that path I see "mywebs~1\bar" ... that is bad. Mywebsearch is spyware. Get rid of it.
Now, this error you are seeing may be from an anti-spyware or antivirus program already removing it but leaving the registry entry in tact. Simply run regedit and search for mp3plugin.dll and remove any instance of it in the registry. This should take care of your problem.
May 15, 2008 | Computers & Internet
Intel Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
