My laptop that is only three months old has suddenely gone dark it was working fine and still is but the screen is very dark and you can only just read things Peter
Thanks for your suggestion Jessica FyfeI I will tomorrow find out how you alter the screen resoulsion and give that a try.Thanks for your suggestion Jessica FyfeI I will tomorrow find out how you alter the screen resoulsion and give that a try.
You can't post conmments that contain an email address.
Hi Peter, Have You Tried Changing The 'Screen Resoulsion' ?
I'm Not Quite Sure How ToDo This But, I'm Sure If You Get In Contact With The Make Of Your Laptop , They Will Give You Some Advice , Maybe Send Them An Email?
Kind Regards,
Jessica Fyfe.
If this is a new laptop barely months old please contact the place you bought it. You will have a warranty on it, you will be able to get it replaced under warranty. It would be pointless anyone trying to help you fix it as it may void your warranty
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Do you see any lights on the laptop that are on? If you see any lights and only a black screen, then more than likely your video chip on the motherboard has gone out. Some local shops might be able to replace the motherboard it might be cheaper than buying a new laptop. Good luck
Well if you take a strong light like a flashlight and you can see a faint image. Then the lamp (CCFL) or the lamp's inverter has failed. It should work fine with an external monitor. Still not good though and usually expensive to repair (unless it is still under warranty).
Hi, i have an Acer 5100 and the screen is really dark... can only just make out the screen. I have tried the fn key trick with no luck. I have replaced the inverter and also the screen.... again no joy. Can someone help me please :)
does the fan work ok? and do you have a laptop holder for it or you just have it on a desk ....get a laptop holder for it if you do not have one and as for the rest goto the power mangment area on the computer and see if the monitor might be on stand by after a few min ...
