Question about Sony Cyber-Shot DSC-F707 Digital Camera
Screws missing on F707 body
Over time i have lost 3 screws that hold the back cap of camera body to front housing. Right now using 3M clear mailing tape to hold it together......Anyone know were to get these screws. I'm sure the local hardware store does not carry anything that small or fine....thanks
    Master:
  • 551 Answers
Another possibility would be to take it to an electronics parts store. Since one can find screwdrivers to fit the camera's very small screws there, I would feel confident they'd also carry the appropriate size screws.
Posted on Sep 12, 2005
    Master:
  • 551 Answers
Without looking at the back of my 707, I would say your best bet would be a watch repairer. Your local jeweler does not repair watches but sends them out: find out where they send them. Usually located in some jewelry center.
Muffler housing
usually 1/4 inch x 20x 3/4-1 long. Measure depth of screw hole and muffler flange. When you find the right one buy cap or stainless steel bolts.
Jan 10, 2012 | Troy bilt Super Bronco Tiller 208cc
I am trying to repalce the drum belt on a Hoover D6530 tumble dryer. What is the easiest way to do this?
here is the procedure to remove the drum:
1) There are 3 screws on the rear at the top that hold a plastic strip, remove the screws and the strip.
2) Slide out the top panel to the rear.
3) In each of the top front corners there is a screw, remove it and slide the top trim bars back and remove.
4) Tilt the machine backwards; remove 3 screws from the front underside.
5) Remove 2 screws from the top panel behind the control panel trim (each one about 2" inboard of the corner screws in step 3.)
6) Take note / photograph the mains switch connections, controller PCB connections and control knob connection. Remove the connectors and the control knob.
7) Slide the control panel to the right and remove.
8) Open the door.There are 2 screws by each hinge on the left.There are another 2 screws to the right.Remove 2 screws on the hinge side that have the same heads and level with the screws on the right.Remove the 2 screws on the right.
9) Pull off the front panel. 10) Remove the lint trap.
11) Remove the 2 screws that secure the lint trap housing to the front support frame. (Look up at the lint trap from the floor, they are under the front edge of the lint trap housing, one on each side.)
12) Support the drum (you can use a solid cardboard box that just fits between the drum and the machine floor.)
13) Remove the 4 M4 head screws (8mm box spanner) that hold the front support frame to the chassis.
14) Lift the front support frame up and pull the lower part forward to release it from the chassis
Mar 06, 2011 | Hoover Dryers
How to take off the right fender off a Mitsubishi 3000gt
Removeal steps
1. Remove wheel arch liner, this is a two peice part front and back. both these need to be removed, there should be 8 screws to remove.
2. You should then have access to all fender screws. There are 10 screws to remove to allow removeal of fender. 4 under the bonnet holding the top of the fender. 2 for the front going to a bracket. 1 underneath the fender where the arch liner was. 2 under the main body of the car towards the front of the side skirts and a final one, near to the door triangle where the mirror is. The fender should then come away but there is a sealant to stop water getting in, make you you reseal when putting back on with 3M ATD, part no 8625 or similar.
Dec 15, 2009 | 1997 Mitsubishi 3000GT
How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Oct 05, 2009 | Hotpoint WMA31 Front Load Washer
How to open dome of honda activa for clean spark plug
You need to open the seat of honda activa and open the screw present in the space provided for tool kit and helmet. Next remove the two screws holding the back rest (the ones above the tail light). Now just lift the body by holding the front end (the one which is towards the steering) there will be a rod below pull it up and let it the body rest on it. You will find the spark plug on the side of the engine (you need to pull out the cap housing the spark plug).
Jun 14, 2009 | 2005 Honda Activa
I have an error code of 5UD or SUD and the water is not draining
If you are getting an F2 error message or a SUD error message, and are observing some water in the tub that is not draining at end of cycle, and your washi cycle is taking a lot longer that normal to complete,then here is what to do.
This solution is easy, and will take no more that 15 minutes, from start to finish, and most of that time is in the --prep-- (getting tools, towels, etc.). This WILL save you a expensive service call.
There are 3 small 9/32 hex head screws that hold the front panel on. The front panel I'm speaking of is --below-- the washer window.
These screws can be found::
a. if you have the optional washer storage drawer unit,, they can be found by opening the drawer, and observing the 3 screws (left, middle, and right side, that hold the front panel on.
or
b. if you DONT have the optional drawer assembly, then they are found on the front, bottom, of the washer, again holding the front panel on the washer.
1. unscrew the 3 hex head screws (9/32 socket or nut driver size)
2. lower/remove the front panel, and set it asisde on some towels, so as not to scratch the front panel.
3. get something now to soak up at least a gallon of water that WILL empty onto the floor.
4. observe large WHITE drain cap, at front center of washer.
5. unscew white drain cap --WARNING-- lots of water WILL drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
6. clean out the front and bottom of the filter trap. I'm sure lint, and gosh knows what else have cloged some of the holes
7. wipe out the inside of the housing for the filter trap (observe lots of -gunk- there too).
8 put back in filter trap, tighten white cap, and put front panel on washer with same 9/32 screws you took off earlier.
Now I ran a test --express wash-- cycle, just to be sure all was OK,, and it was.
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Machine will not drain water I opened the lower cover cap and throughly cleaned it also removed the pump filter which was clean. I have tried everything under the sun and everything is clear yet the...
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 3.5 or a 4. Not too bad.
Mar 15, 2009 | LG WM0642H Front Load
Olympus C60 Zoom I have lost the small housing screws and the camera body is opening, where can I get some?
You should go to a local hardware store and take your camera. Keep checking screws until you find the right size.
Feb 18, 2009 | Olympus SP-510 UZ Digital Camera
Front assembly replacement
remove all straps and battery. remove the 6.1 side plate there are 2 screws under plate 3 on bottom 1 in usb 1 above lcd . remove usb housing . gently pull up on bottom by dock adapter to clear plug then cover should pull off . then remove lcd gently remove clasp that hold lcd ribon . under lcd there is three screws pop flash up slide housing off . battery door must be open to remove rear housing.
Apr 25, 2008 | Kodak EasyShare Z612 Digital Camera
Digital dsc F707 problem
I used Super Glue and my camer ia stil working.  However you need to be very careful taht no glue gets onto the lens itself as it cannot come off and will give your pictures a blurred effect
Sep 11, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
