Question about Microsoft Computers & Internet
Pls help me
Sometimes when i boot my cpu it fasle to correspond
  • 4 Answers
May be some files corrupted
Posted on Aug 31, 2008
Sometimes it turn on but it doesnt boot at all
CPU init is CPU initialisation as you guessed. It should pass extremely quickly however, I'm talking under a second.
The fact that it isn't, or is only passing sometimes, indicates a CPU or Motherboard fault.
Make sure you have the 4 or 8 pin cpu power connector properly plugged into the motherboard.
Jan 11, 2010 | ASUS CROSSHAIR Motherboard
Well my acer laptop is already 1 1/2 yrs old and now it has a problem...sometimes it works sometimes it doesn't.sometimes is cannot be turned one for weeks and it also does charge. i tried to turn on the...
my opinion if it powers but not boot its a hardware problem ...mostly Ram memory ...but if sometimes do not even power up the led or doesn't make at least a click like it trying to **** again an again ..that means that is something with the power system ...and has positions when some contacts are ok and works ...or so ...I can not be sure from what you told here ...but in general there can not be other cause but either physical ( electric) on the power source ..or the boot system messed up ...
Aug 31, 2009 | Acer Aspire 4315 Notebook
Led blinks but fan rotates and stops but pc does not operate and after switching on and off for several times it operates
There is a CD tool called "Ultimate Boot CD" which can be downloadedathttp://www.ultimatebootcd.com. On this CD there are quite a fewtoolsthat you can use to test your RAM, CPU, Hard Drive, etc.. forproblems.Just boot up with this CD and select the corresponding testingprogramto use. Test each component until you find the component causingthe issue.
Cause it seems something is overheating.. Probably the CPU.
Aug 19, 2008 | Intel D845GVSR Motherboard
Automatic shut off of pc
There is a CD tool called "Ultimate Boot CD" which can be downloaded at http://www.ultimatebootcd.com. On this CD there are quite a few tools that you can use to test your RAM, CPU, Hard Drive, etc.. for problems. Just boot up with this CD and select the corresponding testing program to use. Test each thing until you find the component causing the issue.
Aug 17, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Problem with audio driver
haii,
Im using ms 7173 ver 1 motherboard and via chipset VT8237R and AMD sempronprocessor. I have problm with my audio driver so pls help me for downloading the corresponding driver.
Thanks
Sajeesh
Jul 08, 2008 | MSI K8MM-V Motherboard
Boot up problem: No Bios reading
Try to unplug unnecessary hardware.. just plug in the monitor to video card, power, and the memory.. unplug the IDE cable or SATA and also the USB devices... Observe if your system will boot. sometimes hardware damages prevent your system to boot..
Mar 27, 2008 | EliteGroup 741GX-M Motherboard
Not run 1.1
There are a lot of things it could be. Is this a new build or some thing that you have been using that started acting up?. Start be removing all the cards in it that you don't need. Then remove all the cables from the drives. See if it will boot. If it does start adding the cards and drives one by one until you find the one that is causing the trouble. If it still don't boot then check out your cpu or power supply.
Feb 28, 2008 | EliteGroup PT800CE-A Motherboard
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Computers & Internet Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
