Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultimate care II problem
Water will not fill, you can hear a light buzzing sound when you start a load, and the water is supposed to start filling. a small amount of water comes out but after 3 or 4 seconds the water stops. I checked to make sure the water is coming out of the hot and cold spicket and it is.
  • 5,911 Answers
This is a common symptom of a clogged or failed water inlet valve (alos known as a mixing valve). If you live in an area that has hard water, or if you are using well water, it is common for the water inlet valve to clog with rust or sediment. You can remove the valve and clean it if you wish to try and see if the problem will go away. Soaking the valve in some distilled white vinegar can help get rid of sediment and/or deposits. Just make sure you do not submerge the electrical solenoids. If that does not correct the problem, you can simply replace the valve altogether. The following link explains how:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The link gives some helpful advice in eliminating other causes of the a slow fill or no fill problem as well. You can find a replacement valve at searspartsdirect.com. Just type in your complete model number and the part will be listed as item number 18 (part #285805) under the "Controls and Rear Panel" heading. For comparative pricing, you may also try repairclinic.com. They sometimes carry the part for less. Use the part number provided for your search.
I hope this helps you. If you require additional assistance, please let me know.
Posted on Aug 31, 2008
Hello, my washer will fill with water and I hear a relay click when I pull the knob (not just the knob clicking). I also hear a buzzing sound from the washer itself when I pull the knob out but it won't...
PRESS AND HOLD IN POWER BUTTON FOR 15 SECONDS SO THAT ANY INTERNAL ERROR CODES CLEAR THE SYSTEM. MAKE NOTE OF THE LIGHTS THAT FLASH. ATTEMPT TO USE THE SYSTEM NOW.
Jan 26, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water can't fill up
Check and clean out filter inside the connector to the washer
If that is clean
Switch the water off and then start the machine cycle , you should hear a buzzing sound from the area where the inlet hose connects to the washer
If there is no buzzing and the inlet filter is clean you need a new fill valve
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
Aug 02, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Top load whirlpool ultimate care II
Sounds like something got stuck some where take off belt try to spin water pump pulley some times socks get caught if it will not turn take it out and clean it out if you can if not replace it.
Turn transmission pulley it to the left it should be stiff but should turn by hand if not call a service provider. Look at the belt is it worn in spots cracked or show fibers if so replace it.
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer does not agitate after filling with water
does it spin?
sounds like your coupling is broke.It takes the place of the belt if it breaks it won't spin or agitate. it will still pump though.
Part # 285753A
Nov 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Is it dead?
your machine needs a new lid switch
Jul 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
WUC II
check the lid switch, if it is ok go to the pump and see if anythig is in it, if nothing there motor issue
Apr 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
