Question about Sony Cyber-Shot DSC-F707 Digital Camera
F707 Problem w/EVF and LCD screen
I have a problem with my EVF/LCD. At times it will be all one color like red or blue. At other times it my turn yellow on left edge or smear the text w/red edges. ......To correct it I tap it on my hand on the side a few times which corrects it, screen normal in both EVF and LCD. I feel that there is a lose connection inside. ..Is there a exploded view of the F707 for taking apart and putting back togetter again......Thank You for any help.
    Master:
  • 551 Answers
From your description, it sounds like what I've seen described by other people when something has come loose inside-- maybe a cable. If you do a search, I know there are posts where [crazy] people have pried open the guts of their cameras and have written out a step-by-step tutorial on what's in there. If you didn't feel comfy going that route, you might be able to send it to Sony for repair. My vote, if the camera works okay otherwise, would be to just live with it.
Posted on Sep 12, 2005
How can I fix the button that turns on the EVF and turns off the screen? It isn't working.
sir,
I don't understand your question!! how can we use EVF for this model in which it is not fixed from the company, the tilting type LCD is very clear and user friendly in this model.
some old models comes with EVF there may be a small switch beside the EVF. and in some models comes the switching options in the setting menu. if your model is like that you try it in the S-menu.
Jan 10, 2016 | Sony Cyber-shot DSC-HX1 Digital Camera
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Have a fuji finepix S5600, but my lcd remains black even the camera is on! i can see the pictures i already made at the lCD. But LCD is not working if i want to make new pictures??
Hello, I think I know what the problem is..we'll see. On the back of the s5600 there is a button marked EVF and LCD(EVF on top LCD underneath) try clicking this button to see if your LCD screen becomes available, only one of these can be used at a time and the default for playback is the LCD screen. However if you have set it to EVF it will revert back to this format when you leave playback and try take new footage. I hope this helps and it is nothing more complicated. I have some problems myself and know how it feels. Alan
Aug 29, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
EVF is dead
It's a known issue with both the A1 and the A2, and is caused by very poor design of the strain relief to the flexible circuit board which eventually cracks. If you open the EVF you'll see a small piece of blue or yellow tape on the pcb just where the damage occurs: this was clearly Minolta's pathetic attempt to prevent the problem.
There is effectively no fix for this as the only way ro repair it is to replace the pcb and to keep costs down Minolta made the EVF flexi pcb an integral part of the entire pcb which snakes it's way deep into the camera. If only they'd redesigned it as a separate replaceable section then things would have been easier. You'll notice that Minolta omitted the tilting EVF from the successor to the A2, the closely related Dimage A200.
The best you can attempt to do is to peel off the rubber eyecup (it has a tendency to tear, so be very careful) and then remove the two screws from the underside of the EVF. You'll then see part of the EVF pcb. Note that there are actually two pcbs layered together, one does have a joint in it, but sadly it's not the one which has broken. You'll see a red and a black wire connecting to a plug which attaches to a socket mounted on a side spur of the broken pcb. The blue or yellow tape I mentioned earlier will be stuck to this spur (ignore the second piece of tape right near the EVF lens). Now set the selection switch to the EVF position and turn on the camera. By carefully and gently manipulating the broken area (the break is usually microscopic, so don't expect to see the damage) you can usually achieve a position where the EVF lights up. You may need to apply more tape or some folded paper packing beneath the pcb to get the EVF to remain illuminated, and usually will need to give it umpteen attempts so be patient. When it stays illuminated, reassemble and gently fold the EVF back down. You'll often find that you have to repeat the job a few more times as the action of moving the EVF back down upsets the "repair". Once it's down, and the fix appears to be stable (i.e. it doesn't black) out or blink every time you touch the camera) then carefully glue the eyecup back on and use your preferred method to stick the EVF in it's parked position. I use thin double-sided adhesive foam jointing tape: if you live near a modelling shop or know a radio control modeller, ask for a piece of thin servo tape.
The bad news is that this repair will not last and that you'll have to either learn to love the LCD panel or resign yourself to regular re-fixes, but eventually the damage progresses until beyond repair. For the same reason, if you replace it with a used example, go for the A200 instead. It has the same lens and many of the same features as the A2, although ditches many of the useful manual switches in favour of menu-driven settings.
If you are lucky enough to actually obtain a complete and unused flexible pcb then expect three things: 1. it will cost more than the camera is worth; 2. it will cost far more than that to have it fitted; 3. it WILL fail unless you stick the EVF down permanently as Minolta never revised the design. You probably won't find the part though as Minolta pretty well exhausted the spares supply whilst making repairs under warranty.
The same fault occurs to pretty much all cameras which have articulated displays, whether EVF or LCD and is why top-spec cameras aimed at professional users omit this feature. Pro's want reliability and give their gear a hard time, so articulated gadgetry is a liability.
It's a real shame as the A2 was otherwise my near-perfect all-rounder. In my case I only encountered the problem after buying a broken A2 for spares (just for the rubber eyecup and a few minor parts) and just a few weeks after investing in the rare, expensive and vital BP-200 battery grip. I've stopped using mine altogether now as I simply cannot get to grips with composing on an LCD panel.
Sorry this isn't all good news, but hopefully you'll find my posting to be of use and will be one of the lucky ones whose DIY fix lasts. Feel free to ask me for further advice and please don't forget to rate my answer.
Jan 29, 2010 | Konica Minolta DiMAGE A2 Digital Camera
The screen turns yellowish
That is true, problem is as old as lcd projection. Suggest buying a dlp product. they don't color decay
Nov 26, 2008 | Mitsubishi HC5000 LCD Projector
Toshiba portege s100-s1133 lcd screen
A pink or red screen which may gradually turn back to it's appropriate color indicates the lcd is going out. It could last quite some time in tht condition, but it's going. replacement isn't too bad though.
good luck
Jan 20, 2008 | Computers & Internet
Dust Behind Lens on F707
That's odd. I had the 707 (may she rest in God's eternal peace), and never thought that dust could get behind the lens. Do you see the dust when you look through the EVF, or when you look at the lens itself? Either way, one way to test it is to set the camera to the smallest aperture (f/8), infinity focus, and shoot a clear blue sky. Open the picture in your editor program, and see if the dust shows up. That's a technique to use with an SLR to see if the dust inside would affect a picture, so I'm not sure if this will work with the 707.
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
The colour on the EVF and LCD is pretty pink and nearly red
Yes it is. I believe Panasonic knows that the built in flash casts a very blue tint so they set the flash WB to very red to compensate. Therefore before the flash is triggered as when you watch the LCD. Some threads here even suggested adjust the WB further 2 knots to the red manually (press " up" a few times on the 4-way button to have better skin tone. Try it. The setting stays even when you turn off the camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
