I NEED MY RADIO CODE FOR MY HONDA ACCORD EX
Radio codes are avail. from the origional dealer. If you did not purchase the car new usually the original dealer has them. You will need to show proof of ownwership. Hopefully the original dealer has not perched his records.
These codes are needed every time you disconnect your battery.,if you ever want to use your radio again
If u cant find it on the radio get ur vin # and the s/n # that is on the radio it self (u will need to pull the radio out of the car to see it it will be located on top of the radio and call the dealer they can get u the code from their
I was just told this just the other night at work. she said it is on the radio either around the fuse or on the radio itself. im sorry i cant be more detailed but it is on the radio. hope this helps some just pull the radio and look around on it.
Anzee74..the one on the radio itself isnot the codebut the serial numbers which you will need to get the codes when you go to the dealer or when you want to purchase the code online..
i got the same problem when i took my car to the repair shop for transmission problems..they disconnected the battery so the radio is requiring a code..
