Question about Sharp CD-BA200 CD Shelf System
My stereo Every time i turn on the stereo PROTECT comes on and the stereo shuts down...
  • r_cookie_26 Sep 17, 2008
    my stereo was unplugged and now being plugged back in its displaying PROTECT and wont go away, HELP!!! I cant do anything, off, on open, etc.......
    New Friend:
Were is it at can I fix it myself or got to tack it to the shop
Posted on Mar 18, 2015
  • 82 Answers
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Posted on Oct 04, 2008
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
Car stereo cuts out
It is possible a self-protect feature may be shutting down output. Check all of your wiring, following the manufacturer's instructions exactly. Faulty wiring is a major cause of poofed audio output devices in car audio. Any short in wiring, or an open (intermittent or otherwise) can cause a problem here. Internally, bad solder connections where the output devices solder to the board could cause problems too.
Jul 03, 2007 | iLO XM-MP3-CD Car Stereo
XL-MP60 Shelf System: stereo shuts down and reads protect...
Hello, the problem of you stereo appliances been shut down was as result of a mechanism jam of the system.
The way you could do this is to open the back cover of the appliances and check for the rubber attached to the motor of the appliances, also check and see if you can adjust the mechanism if it is a disorder manner, it require a careful approach.
This will require a skilled personnel to handle this
May 17, 2010 | Sharp XL-MP60 Shelf System
Protected
You got to open this puppy up and replace the 2 bad IC boards.  Known problem with this brand stereo.  Defect in the IC boards causes your fuses to blow and they will keep blowing every time you try to put new ones in.  Cost for parts will be about $200.
Aug 15, 2009 | JVC MX-GT88 CD Shelf System
Everytime i turn on the stereo it shuts off an says protect
When sound system shows Protect that means it got problem in amplifier section and protection circuit is activated that shuts down system in safety. Qualified tech will fix it.
Jul 31, 2009 | JVC HX-C6 Shelf System
Stereo goes into protect mode
Protect is a safety feature so that you do not blow your speakers. However with it hooked up with the computer you may have surpassed the max output. If it still does this with out going through the computer, it has been damaged.
Mar 14, 2009 | JVC MX-KC45 Shelf System
Protect mode
i try to turn the stereo on a message saying "protect" comes up and then it shuts off
Apr 28, 2008 | JVC HX-D7 DVD Compact Stereo Audio / Video...
How to turn protect off
You cannot . This a feature that detects a short and shuts the stereo off before it can do further damage. If you can disconnect your speakers try that then turn on your stereo. If it displays protect mode your problem is internal. If it stays on try hooking up one speaker at a time to see if one of your speaker is bad. Make sure you turn off your stereo before attempting to reconnect your speakers . Good luck
Mar 03, 2008 | JVC HX-D7 Shelf System
Protect mode
Hi ,
Does your unit go into protect mode without speakers connected?.
Jango
Jan 26, 2008 | JVC HX-D7 Shelf System
Protect
The audio amplifier of your device are damaged and you need to replace him.Good luck
Nov 15, 2007 | JVC HX-C6 Shelf System
Sharp CD-BA200 CD Shelf System Logo
485 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
