Question about HP Jornada 548 Pocket PC
Jornada 548 won't print to IR on hp 450 mobile printer
I've dl'd both PPC printer drivers for the hp 450 and neither one works with the 548. any suggestions?
    Master:
  • 450 Answers
The ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Posted on Sep 12, 2005
HP Jornada will not access my secure network
your router must allow this.
if no idea at all what rounter you have
the SSID is just broadcasted name, use a personal made up name like ROVER2, or your dogs name, etc.
the WEP is , no longer safe, web is very hacked.
but many old HP relic devices many only do WEP.
and most routers now deleted or is turned off by default (wise they are)
so turn on WPA
then set a passphrase, matching the router.
Jan 30, 2018 | HP Jornada 720 Pocket PC
HP Jornada 548 files won't sync with Vista PC
No need to! all u need is to download windows mobile device centre at:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx
that should help you!please do rate if it does,regards!
Nov 21, 2008 | HP Jornada 548 Pocket PC
Duplicate alarms
I may be off base but might the problem be as simple as the frequency being set for the alarm. What I mean to say is, might the default reminder time for the alarm be set to such a low setting like sec's or minutes leaving the unit to repeat the alarm rapidly prior to your being able to dismiss/snooze. Good luck.
Sep 14, 2005 | HP Jornada 548 Pocket PC
Pocket Access - does it exist on HP540?
No, sorry, the Jornada 540 does not have Pocket Access on it. The Jornada 720 does, however...
Sep 12, 2005 | HP Jornada 540 Pocket PC
AC Adapter Buzz Noise
The jornada 548 power adapter should not be buzzing - it should be very quiet.
Sep 12, 2005 | HP Jornada 548 Pocket PC
Jornada 547/548
When you smell burning silicon thats a sure sign you are going to need a new one. Sounds like some pretty severe damage to chips if it smelled up the whole car. But the battery charging light still working is a good sign, which means its not a total loss.
Sync problem w/outlook contact
I use my 548 to keep my work and home versions of Outlook syncronised. I have about 70 contacts stored. Three suggestions.. 1) Do you have enough free memory? Emails can take up megabytes, and for that reason I choose not to sync emails. 2) Are all of your contacts in the same Contacts folder? I have two contacts folders on my home Outlook, one for me and one for my wife, I only sync my contacts to my 548. 3) In Activesync, click on Options, Sync options, contacts, settings and make sure that "Syncronize all contacts" is checked
How to use IR
I have another model, but maybe this will work: In the explorer under file you will likely have send and receive menu items. Similarly for pocket outlook applications.
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Time off by one hour
a pocket PC that still runs. wow. a blast from the past, 2000.
16 years it works ok , then today it fails?
you need to set time zones. and if you have DST , day light savings time in your unstated locations.
finding a manual on anything that old is problematic to you and most other helpers,
good luck with that.
Apr 12, 2017 | HP Jornada 548 Pocket PC
HP Jornada 548 Pocket PC Logo
100 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
