Question about NEC PlasmaSync 61MP1 61 in. Television
NEC 61 MP1 does not turn on...
I had the apparently common "bottom half of screen image syndrome", but after a few times of turning the unit on and off, the full image would eventually stay on.   Last night all things were well, but this morning the monitor turned on for a few seconds and shut off.  The screen does not come back on. The green LED indicator light turns on, a few minutes later the LED begins to blink in a pattern 3 green LED blinks then 1 red LED blink (it repeats).  I am hoping one of you geniuses can help me.  Thank you.
3 Suggested Answers
SOURCE: NEC Plasmasynch 50 MP1 won't turn of
very expensive to fix sellthe tv for part
Posted on Sep 25, 2007
SOURCE: NEC PLASMA SYNC 42MP2 STANDY BY MODE?
According to the manual for "POWER/STANDBY indicator is blinking in red":
  • "The temperature inside the main unit has become too high and has activated the protector."
  • "Promptly switch off the power of the main unit ans wait until the internal temperature drops."
  • "If the monitor becomes too hot, the overheat protector will be activated and the monitor will be turned off. If this happens, turn off the power to the monitor and unplug the power cord. If the room where the monitor is installed is particularly hot, move the monitor to a cooler location and wait for the monitor to cool for 60 minutes."
Posted on Mar 01, 2008
SOURCE: nec 42'' plasma
Try holding down the 'INPUT SELECT' button, then press the power button on, on the tv at the same time.
Posted on Jun 05, 2008
How to fix mirrors on NEC NP400 projector?
how to fix image that is half darken on a NEC NP400
May 03, 2012 | NEC NP400 Projector
Monitor displays half screen sometimes and goes back to full screen later. Some days you get the full screen but today it is half screen one time and then full screen another time. It finally quit...
The monitor have problem in vertical section of the board.Maybe the vertical output or any parts around the vertical ic is loose connection circuit,what we called,cold solder so its better to resolder the board at the vertical section.
Jul 11, 2011 | NEC PlasmaSync 61MP1 61 in. Television
Plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
May 15, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Purple image captured with EOS 450D
Definitely bring it for repair. Apparently there is something wrong with the sensor.
Jul 13, 2008 | Canon Cameras
Just a half picture on the screen
1. Remove the rear cover 2. remove the perforated large shield on the main board housing (almost in center). 3. Unplug the right top fan and temp sensor plugs ( two small plugs at the top of the main board). 4. Remove screwsthat secure the main board housing, there is also four screws by the video inputs. Do not unplug the board, just gently pull it away 6 to 8 inches. 5. Remove the cover with the Top fan attached (more screws). 6. Now the scan board for the top half of the screen is exposed. The board has four large heat sinks with two large Electrolytic aluminum caps next to each heat sink. 7. The problem caps are at the very top right side of the scan board C192 Nichicon 220 uf next to the IC, the other cap is C120 100UF on the lower side of the IC next to a heat sink. I replaced them without taking the board out. C192 is the one that failed, the other one tested OK but I replaced both.
I got the caps from Mouser.com they are 69 cents each, the Mouser part number for the 220Uf is: 647-UUD1C221MCL1GS (Nichicon 220uFm 16V 6.3x7.7 mm surface mount); the 100uF is:647-UUD1E101MCL (Nichicon 100uF 25V 6.3x7.7mm), both are 105 degree C. I bought two extra spares in case I need them for the future.
Reassemble the unit in the reverse order and you are done. Note if you test it without closing everything, make sure you have the main board shield back on, otherwise the screen will bleed due to the noise from the board. good luck! mine has been working fine.. just like new..
May 16, 2008 | NEC PlasmaSync 61MP1 61 in. Television
NEC Plasma
thats bs, stop calling nec, there are plenty of repibuble repair shops who have or can get aftermarket part
Oct 12, 2007 | NEC PlasmaSync PX-61XM3A 61 in. HDTV-Ready...
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
NEC PlasmaSync 61MP1 61 in. Television Logo
99 people viewed this question
Top NEC Televison & Video Experts
Dave Naylor
Dave Naylor
Henry  Thomas
Henry Thomas
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
