Question about Miele S251i Plus Bagged Canister Vacuum
Burnt out resistor
I need the wiring diagram so i can find the value of one of the resistors on the printed board near the motor, which looks burnt out
I'm in the same fix. I learnt that a new pcb is £68 so had the pcb repaired but after the machine has warmed up it now cuts in and out. Like you, I haven't been able to locate a wiring diagram so am trying a last minute lash-up before binning the machine:
A friend suggested that since we all seem to only operate the cleaner on full power I should connect the on/off switch direct to the motor bypassing the rheostat and the pcb as in old fashioned machines.
Posted on Jul 07, 2009
How to disassemble my Miele s718 vacuum
Large grey capacitor (if the same as my S571) should have a value of 0.22uF/275V but if you take it out it will have its value printed on it.
May 29, 2014 | Miele S318 Bagged Canister Vacuum
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
Dyson dc 15 brush roll not spinning. motor is good, upper switch is good.
Open the right side of the vacuum with a hex head screw driver. There are 4 screws. Inside you will find a circuit board.
1. Make sure the varistor (S20K150) is not blown, these models seem to have an issue with this. It is a flat blue "quarter" looking component near the top edge of the circuit board.
2. At the bottom of the circuit board are two white wires connected via push on connectors. Remove these from the circuit board by sliding them away from the circuit board. Power on the vacuum and engage the drive button. If the lower motor still does not engage check step 3.
3. A blue and yellow wire runs off the bottom end of the circuit board. These are the wires powering the lower motor. Check continuity with a multimeter and make sure they are not broken. I have seen where these wires will break as they run through the housing of the vacuum. If they are broken, replace them with any wire of the same gauge.
Dec 15, 2010 | Dyson DC15 Animal Bagless Upright Cyclonic...
Need Bissel 1715 wiring schematic. Charging circuit has burnt resistor. Need to know resistor details.
Can not believe NO ONE could answer this.
The R1 resistor basically drops the 9V to around 5V for charging the battery pack. The resistor is a 10 ohm , 2 watt resistor. The other resistor is 220 ohm. This only limits the current to the LED.
The 10 ohm resistor burnt because the battery pack was left to sit too long without use and charging. So the cells shorted causing excessive current through the resistor when you attempted to charge the batteries.
After replacing the resistor, you will need to replace the battery pack before charging. Otherwise, you'll just burn the resistor again.
Sep 27, 2010 | Bissell 1715-G Spotlifter Bagless Handheld...
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Henry's motor burnt out
You should have 3 wires one of them are green . gr. is the ground . the other 2 are interchangable. good luck DFD
Aug 07, 2008 | Henry Numatic "" Canister Vacuum
Hoover Savvy Model U8181-900 Rewiring
The brush roll motor is most likely what caused the problem to the circuit board. You would look at about $100 or so for the 2 parts.
Jan 16, 2008 | Vacuums
Miele S251i Plus Bagged Canister Vacuum Logo
421 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
