Question about Sony STR-DE625
Protector flashing on unit - Sony STR-DE625
  • 2 more comments
  • tlog Nov 13, 2008
    I'm having the exact same problem. I also have a dial and not buttons for the speakers.
  • tlsp Nov 16, 2008
    STR-DE625 - The protector light keeps flashing everytime I turn the system on - all the manual says is that there's a short circuit and to turn off the receiver, eliminate the short-circuit problem and turn on the power again. The only thing that the receiver is hook-up to are the speakers. Could there be a short in the speaker wiring?
  • Anonymous Nov 17, 2008
    I have the same problem with me receiver techwood receiver the protect light on when I turn it on
  • djcarlos2001 Mar 09, 2009
    I have the same problem on an SR6001 which is about 10 months old. I've since sent it back under warranty so will wait to see the outcome. My unit went into this protect mode about two or three times a month after being on for about 20 minutes. A simple power off and on would clear the issue and the unit worked fine.
This unit does not have a A & B speaker button it has a dial
Posted on Sep 03, 2008
  • 3 Answers
Push the power button when its off and the A and B speakers buttons at the same time for 30 sec. wright back to let me know how it goes..ok
Posted on Sep 02, 2008
How do I reset the protector
By "the unit" I take it you're referring to some audio device? If so, you most likely have a short in the speaker wire.
Sep 03, 2014 | Cars & Trucks
When home theater is turn on, protector push power is flashed on thee screen. player will not function further. volume level is 9. currently can't be turn down.
Protector means there is a short circuit somewhere in either the speakers, the wiring or inside the unit itself....you can try disconnecting all the speakers and then turning on the unit...if the protector goes away, then you have a bad speaker or bad wiring to the speakers....if the problem stays, then there is a faulty circuit in the receiver itself and will need to be serviced
Feb 05, 2011 | Audio Players & Recorders
When I push open or close the unit starts but stops the yellow light on rear of unit blinks 4 times then a short pause and blinks 4 times again and continues to do this
# of flashes
6
Rapid Flashing
Problem
The Protector System wire open or totally misaligned
The Protector System wire shorted or black/white wire reversal
Door Control or Multi-Function control Panel wire shorted
IR sensor slightly misaligned (dim or flashing sensor LED)
Motor overheated/Possible RPM sensor failure -- unplug to reset
Motor circuit failure -- replace RX/LX board
Liftmaster transmitter with the correct format code being received
(opener not necessarily programmed to respond)
Mar 28, 2009 | liftmaster Chamberlain Garage Door Opener...
Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Dec 31, 2008 | Audio Players & Recorders
ONKYO DR 90 STANDBY LIGHT FLASHES UNIT WONT START
hello sir
if protector activated its means there is shorted speaker connected to your amplifier,try to remove all speaker and turn on your amplifier,then make sure your amp volume is in low position.if the protector is de-activated its means one of your speaker is shorted.then try to find out
Dec 13, 2008 | Onkyo DR90
Syncing Nikon D300 with 600VR strobe system
A wireless system such as the line of Pocket Wizards is a good choice- the are builr to professional standards and are very reliable.
If you wish to hard wire your flash unit to your digital camera, you can purchase a protector wivh reduces the trigger voltage to a safe level refatdless of the age or design of the flasg system you are goinf to use, Under no circumstances should you use this combunation of equipment without a radio triggering device or the protector, The protector attache to the hot shoe of the camera and provides a standard PC synch cord terminal for connecting your flash system to the camera.
You can test the voltage by putting a volt meter set a 250 or 500 VDC across the synch socket in the flasg unit, If the meter deflects negatively just revers the polaity for a correct reading. If there is under 5 volts there is ptobably no issue, however, I still would take no chasces abd use a radio or a protector. If the falsh won't fire with the radio or protector in place, tha probably means tha the synch voltage is very low.
Nov 22, 2008 | Novatron 1000ws Standard Head with 25'...
Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Mar 11, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Protector flashing sony da80es
could be fuse inside open it up cheak all cheall all conections start with just 1 unit in it
Feb 06, 2008 | Sony STR-DA80ES Receiver
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Sony STR-DE625 Logo
439 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
