Question about Acer Aspire 3050 Notebook
CD burn I use to be able to burn cd's but now my burner won't work, it reads discs but just won't burn when i put an empty disc in it says it is full already, what the heck. Kinda hard to create a recovery disc whn you can't burn.
  • tazweld Aug 31, 2008
    Can't burn cd's pc see the drive but thinks the disc is full already and yes I put a new out of the package disc in. several actually.
  • tazweld Sep 01, 2008
    I have all I was told is there must be conflict between programs. Great thats really helpful. I have taken it in and had the local tech wizard try to fix it and he said the same thing. I bought and external burner and it does the same thing that the Acer does. it see's the drive and disc but shows and recognizes the disc as being full. Lets this be a lesson to all, I should have bought a Mac.
    Problem Solver:
  • 14 Answers
I Think Your Best Option Would To Get In Contact With Your Laptops/Pc's Make , Im Sure They Will Be Able To Help You (:
Kind Regards,
Jessica Fyfe.
Posted on Aug 31, 2008
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
No music on burned discs
You need to try a commercial cd of any kind. You just want to see if it reads the cd. Then you want to try a dvd and see if it reads that. If it reads the cd but has trouble with the dvd then the heads are out of alignment. It might still write a cd but not be able to write a dvd as that require more accuracy and it doesn't have it anymore.
You may still be able to use the drive but you will have to replace it. The symptoms you describe are typical of the driver going out of alignment so I would say you are heading for replacement sooner or later.
These are not cost effective to repair anymore so all you can do is replace them. Unless you can get it replaced under warranty you can replace it for under $50 at any local computer store.
Jul 10, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
I have a gateway with windows xp and my dvd rom won't read dvd-r
it could be that your dvd drive is only able to read dvd discs not to burn them, if its a combo drive its very likely a cd burner that can read dvd discs.
if you send me the brand and model or the full name / details of the drive I could check on it.
Jun 03, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Not find disc in drive
Sounds like you need to install a DVD decoder, Roxio, WinDVD and PowerDVD are good decoders.
May 20, 2009 | Sony DRU 530A DVD±RW Burner
Samsung SHW08A DVD±RW doesn't burn dvd+r
Its because you need a firmware update. The media you are currently using isn't recognized. I stumbled in here with the same problem. I haven't been able to find an update, so I will probably have to try a different brand of disc myself. The burner worked fine until I tried using a new pack of Verbatim discs.
May 21, 2008 | Samsung SH-W162C 16x16x8x6x5x4 DVD +/-...
Won't burn CD-r or DVD-R
make sure that your program that is setup to record. i.e nero-img burn et,c. is set to look at the drive D:- Or E:- whichever letter your drive is assigned by the computer.
Also try using a different Blank-media. if any disk has failed a full write, without finalizing Or creating the Table Of Contents. It will read as Empty Or Blank. you can see This By looking carefully at the underside of the Disk, to see whether it has been burned by the laset. ( Towards The Centre ) if the Dye is darker on the inner-edge, then this is possible.
You can also try using a different Packet writing software, or re-install the program.
Hope this helps.
Mike @ Compurepair.
Feb 22, 2008 | Sony DRX-710UL DVD±RW Dual Layer...
Cd rom drive does not work! NEEDS ASSISTANCE!
Magnit can damage your Cd drive, maby it is damaged.
Nov 14, 2007 | HP Pavilion (PN153AAR) PC Desktop
CD Burner
This will be a burner problem as in the laser is no longer able to read a disc and tell if it's full, empty or formated. I doubt it's a software problem, but you may have a faulty cdr disc so check a few or a different make as not all are compatable with all burner makes.
Apr 20, 2007 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
Acer Aspire 3050 Notebook Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
