Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire FRS26ZSH no water at dispenser or ice maker
Our ice maker and water dispenser were working perfectly untill we came back from a 5 day vacation. Untill then the water dispener and ice dispencer were used every day.
I have checked the supply and we have plenty of pressure where the water enters the fridge. I've unhooked the water line from the output side of the first solenoid and when I press the dispenser lever the water gushes out. When I try the same thing where the water enters the second solenoid (bottom right side of the fridge looking from the front. This looks like it is fed from the top of the fridge near the filter) there is no water. After that I tried thawing the water reservoir with a hair dryer. I've unplugged the fridge to help with any freezing in the lines. I've taken the filter out, filled it with water and left it on the counter to check if the water will flow through the filter and it does. I've tried the dispenser with the filter in and with the filter out.
Still no water!!!
Any suggestions?
  • 2 more comments
  • bjarvie Sep 02, 2008
    Hi John,
    I removed the assemblies and took them apart to clean them. They looked pretty clean! I've put it all back together and now when I press the dispenser there is a clicking noise comming from the back of the fridge. Once my wife comes home I'll have her press the dispenser and see if I can figure out where the click is comming from.
    If I replace the solenoids, I assume that it is just the coloured parts with the twin connectors that need to be replaced and not the complete unit. For example the green and yellow parts not the bue parts.
    Bill
  • musicmanboy Sep 19, 2008
    neither the ice maker or water dispenser works. I took off the filter and when I push the water dispenser, a very small trickle of water comes out - very small. Checked the plastic water container - it's not frozen. help!
  • Anonymous Apr 30, 2009
    I have no water to the ice maker and the water dispenser
  • ralbanes May 11, 2009
    I have supply water to the first solenoid. I don't get any water out when I push the water dispenser button. I checked for 115 volts on the solenoid and had none when I pushed the water button. I also checked the solenoid coil with a ohm meter and it was not open, showing resistance. Any ideas were to go to now.
  • 55 Answers
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Posted on Aug 31, 2008
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26ZSH -ice & water dispenser panel lost power
I think you will need to unplug the pin plug under the cover at top or bottom hinge. Check the voltage and if OK leave unplugged until you can remove the dispenser and I will try to help you from the power source. Sounds like a short in the board and related to the light socket. The fuse only stopped the short from doing further damage, You may need to locate the short before replacing the fuse or board. I have looked over the wiring diagram. If you find the short without my help just be sure to replace the fuse with the correct size. The only things are the chute heater or something in that area of the board went to ground. Do you have a voltage meter? Contact me later when ready, Sea Breeze
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice and Water dispenser
no manulal reset or fuse, buth tere is ususlly a "child lockout" feature prevent ing the dispensor from operating. check to see if the control has been placed, on, or perhaps the door is not closing fully, another reasom for the dispensor to stop
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Side by side frigidaire ice maker not working
Check the water valve at the back of fridge. Are you getting water at the dispenser on the door? If so, the water valve may not be bad, but sometimes water will freeze in the tube that fills the icemaker. Pull it out from the back of the fridge and check it.Hope this helps !
Oct 08, 2017 | Frigidaire FRS26R4A Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
2,172 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
