Question about Asko D1776 Stainless Steel Built-in Dishwasher
Asko D1996 The top rack keeps sliding out all the way whenever the door is opened. I don't know if there are stops that have come off or what the problem is. Any help would be appreciated?
  • 639 Answers
Peace friend,
ngfam1 at your service
It is the stops .
You can call this parts house and they will help you figure out the part #'s. If they have them in stock they will sent them usually in one day.
or you can see the parts in the user manual too!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
How old is the appliance?
If it is 9 years old or more it may be putting god money into bad!
The new ones pay for them selves in a few years on the savings of energy, and water because they clean better with less water!!!!!!!
A much better n you electric bill!
If you need a good repair Here is who I recommend nation wide.
A&E Factory service open 24/7 for appointments!
1-800-905-9505
Ngafm1
PLEASE GIVE ME THE BEST RATING BEFORE YOU SIGN OFF! BLESS YOU
Posted on Aug 31, 2008
ASKO 1375 Dishwasher top rack keeps rolling out
Your dishwasher may have sagged since being level when installed.
May 20, 2016 | Asko 1375 Dishwasher
Rinse aid dispenser not working
You have to take apart the whole door panel to see what the problem is,.
Jun 07, 2013 | Asko Dishwashers
Top drawer
Hello, Welcome to FixYa. Based on the info you provided it's likely a pretty easy fix. The machine is leaning forward slightly and it shouldn't be. Remove the top screws fastening the machine to the counter...if applicable, some are on the side if granite counters or similar exist etc. Then take off the lower kickplate/access panel and screw the front leveling legs down ( which will cause the tilting of the machine back slightly ) and screw the back legs up, hence the rack should no longer slide out on it's own. There are also locking nuts for the legs so make sure you loosen amd re-tighten them in the process. Let me know how you make out. The most difficult part will likely be the removal and replacement of the toe panel/kickplate. Good luck, Macmarkus :)
Aug 02, 2010 | Asko D1706 Built-in Dishwasher
Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Dec 25, 2009 | Asko 1385 Dishwasher
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Feb 28, 2008 | Asko D1776 Stainless Steel Built-in...
My problem is with a Asko D1996
Remove the panel down on the backside of the machine. Dry ut the water on the bottom pan with a towel or so. Should work like new;)
Jan 27, 2008 | Asko D1776 Stainless Steel Built-in...
Top Rack always slides out fully
Well, you are right on about the level. It is tilted just slightly forward. The only parts to go bad are the plastic ball bearing guides, and usually when they go, you get a rack that wont come out and gets jammed. You 've got the problem, you just need to remove the screws hidden in the holes that are sometimes coverd with rubber plugs so that the dishwasher may move freely, andjust it till it no longer rolls out, then screw it back to the counter to hold it in place. There are no springs in that rack, so either its still tilted forward, or the tank is bowed or bent somehow, and that would mean new dishwasher. Hope this helps!
Jun 19, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
298 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
