Question about Dryers
Old DANBY elec dryer DCD411 - drum belt snapped
I have an old Danby DCD411 that needs a new drum belt. Motor still working with heat, but drum wasn't turning, so I took top of dryer off and found belt at back of drum had snapped. It has one side that looks like train tracks with 2 grooves and 3 ridges.
Can I find a compatable belt anywhere or is my dryer toast. I haven't been able to find anything as compact and I have a very tight space in an apt for this.
kathyluvsanimals@yahoo.ca
Thanks
    President:
  • 1,462 Answers
Most belts have the length written on or take belt to a good general spares stockist and see if it can ve matched
Posted on Aug 31, 2008
Blowing heat, not spinning!!!!!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 11, 2010 | Danby DCD5505W Electric Dryer
My danby dryer DCD 5505W is making a squeaky noise.
You need to change its Drum bearing and front rollers. Also replace its Drum glider/pads.
Jan 09, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
How replace belt danby electric dryer dcd5505w
Remove the retaining screws off from the front panel. Remove the two wires connected to the door switch(the wires can go back on either way).Pull the front panel away from the drum. Look down to the bottom right corner facing the front of the unit and locate the tensioner and drive pulleys. If the old belt is still intact(which is usually not the case) remember the routing order of the belt. Slide the new belt onto the drum keeping in mind which side goes to the drum. The ribbed side should face outward.Next you want to curl the belt over the tensioner(providing the tensioner is still in it's slot) and then over the drive pulley. Replace the front panel and the door switch wires. You're good to go. Thank you, Dana
Oct 06, 2009 | Danby DCD5505W Electric Dryer
Danby twin washer/spinner
should have a belt idler or tensioner between the motor and the drum
Sep 13, 2009 | Danby DTT420 Top Load Washer
My Danby dryer dcd5505w hums but wont tumble. I opened it up and pushed it and it ran for a bit and stopped. I pushed it again and it ran for about 3 minutes before stopping. The motor is okay and so is...
the motor is most likely the cause. once it starts to hum, it's not spinning :( bad brushes inside. replace the motor or get new dryer, sorry :(
Joe
Aug 26, 2009 | Danby Dryers
Push start button but won't start after belt replaced
Did he remember to plug in the door switch on re-assembly?
Jun 12, 2009 | Danby DCD5505W Electric Dryer
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Oct 23, 2008 | Danby DCD5505W Electric Dryer
Where can I buy the dryer belt?
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Sep 29, 2008 | Danby DCD5505W Electric Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
