Question about Garden
I have a Craftsman Mower that I don't have the manual on but I need to change the oil and filter?
It is a Caftsman 5.5 engine mulching mower
Maybe the yardman doesn't have an oil filter
Posted on Nov 02, 2008
How much oil and type of oil for my craftsman 42" mower
Oil capacity and type depends on engine size, manufacturer of the engine for the mower and whether it has an oil filter too. There should be a label stating model number near the battery that is under the seat, or it may have information for oil volume inside mower "hood". If you get the model number, it's possible to download a file for the manual at no cost.
Nov 01, 2017 | Craftsman Garden
I don't have an owners manual. I need a new oil filter for Craftsman LT 1000
You need the model number off the engine. With the model number and the brand you can go to the local lawn mower repair parts shop and get the filter for that engine. But if you would like to send me the complete model number and the brand of your engine I will look it up for you to get you the part number so you know what to look for when you go to get it.
Aug 12, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
CRAFTSMAN 20" MULCHING MOWER MODEL
You have to take the bowl nut off he bottom of the bowl and clean it with a small wire or torch cleaners. Try not to allow the bowl to drop off the carb, the float drops down and the needle might come off the float.
Mar 11, 2011 | Craftsman Garden
I changed the blade, and now it won't start!
Did you replace the blade with a heavier blade, or an identical one? If the pull cord won't pull, it's usually either the blade or the blade shaft causing the problem. Try oiling the shaft and making sure nothing is obstructing the blade from turning.
If you have a pair of heavy gloves, try turning the blade by hand and see if it moves. Squirt some oil onto the shaft where it meets the mower and try turning it again.
May 25, 2010 | Craftsman 22 in Precision Cut Lawn Mower...
I have a 13 HP rear engine Craftsman mower SP need Serial NO.
go to a crafysman tractor forum ask your question and youll get your answer.
Nov 06, 2009 | Garden
Oil change
hi,the engine uses sae 30 oil,takes about 1 litre of oil,you can get this from most garages or mower centres,hope this helps
Apr 08, 2009 | Craftsman Garden
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 6.5 lawnmower
The bag return on the 6.5 sits on two hooks. Standing to the left of the mower you should be able to grab the back handle with your left hand and then left the metal protective flap with your left hand so you can raise the bag assembly still in your right hand up and out of the two hooks. You'll then need to put back into the mower the mulching kit which blocks the rear discharge and makes the underside of the mower a complete circle so the mulching effect works. Obviously the mower will physically work without the mulching kit because the metal protective flap will cover the rear eject but it will NOT effectively mulch the clippings and you will get longer pieces that clump.
Hope this listing isn't too late to help.
sean
Apr 28, 2008 | Craftsman Computers & Internet
Garden Logo
483 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
