Question about Palm Zire 31 Handheld
Could not complete the operation. One or more parameter values are not valid.
When I close Outlook 2000 after having opened a Note for edit or read-only, I get the following error messages: "Could not complete the operation. One or more parameter values are not valid." -and- "The note will close and your changes will not be saved." Oddly, the changes, if any, are saved. But, the message is annoying. When I researched this message, Microsoft has a KB note (KB842942) regarding Outlook 2003 and a Live Meeting Add-in. The only thing close is that I recently ran, thus configured, NetMeeting - all of which aftermy Palm stuff had been installed. Oh, I also logged onto a WebEx meeting, which installed something, too. Is there a way to correct this, if it's Palm related, w/o having to uninstall and re-install all of this stuff? Thanks!
I had this exact same issue. Here was my solution:
As you know, notes are named using the first line in your note, and special character rules apply to the name of your note. In my case I was creating a note like "New/Used Machines" and detailing my notes within. The forward slash is a BAD character to use, so the solution was to just change the slash to a dash so that my note is now named "New-Used Machines", and poof. Problem resolved.
Bottom line, stick to alphanumeric characters and maybe the dash in naming your notes, and the problem will go away...
Microsoft should fix this because it would be so simple to give the user a meaningful warning message, and prevent you using invalid characters in the name.
Posted on Dec 02, 2009
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
I work for WebEx and its not Webex issue, its VB SCRIPT Error
Posted on Sep 02, 2009
Logon Change
Enable Log-On Screen
Windows, by default, is set to show the Welcome screen during startup.
To enable the log-on screen to show, go to "Start" menu and select "Control Panel".
In the control panel, click on "User Accounts".
In the "User Accounts" dialog-box, click "Change the way users log on or off" and uncheck the "Welcome Screen" option.
Click "Apply Options" to save the changes.
Change Log-On Screen Background Color
To change the log-on screen background color, go to the "Start" menu and click on "Run".
In the run dialog-box, type "mspaint" as the name of the program to "Open".
Click on "OK". In the "Paint" window that opens, select "Colors" from the main menu and click on "Edit Colors". In the "Edit Colors" dialog-box, select "Define custom colors".
Here pick the color of your choice and note down the "Red", "Green" and "Blue" values.
Write down these values somewhere.
Click "Cancel" and close the paint window without saving. Now, go to the "Start" menu, click "Run" and enter "regedit" as the name of the program to "Open".
In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\COLORS and double-click the "Background" string.
In the "Edit String" dialog-box that opens up, change the values in the "Value data" field to the red, green and blue color values that you wrote down (e.g. 75 78 173).
The default value will be 0 78 152. Enter the values in the correct red-green-blue order, separated by a space. Close the registry editor and log off to see the changes.
Put Image in Log-On Screen Background
To put your favorite picture in the background of the log-on screen, click "Start", then "Run", and type in "regedit". In the registry editor, navigate to HKEY_USERS\.DEFAULT\CONTROL PANEL\DESKTOP and double-click the string "Wallpaper". In the "Edit String" dialog-box that opens up, enter the full path and filename of the image that you want to use as the background. The image must be in .bmp format. Click "OK" and close the registry editor. Log off to see the changes. hope this helps
Oct 03, 2012 | Microsoft Windows XP Home Edition for PC
Tip
Recovering deleted items in Outlook 2003 and 2007
If you accidently deleted items like Emails, contacts, calendar, tasks, etc from your mailbox using Outlook, you can recover them as they are first transferred to the Deleted Items folder of that mailbox. But even if you delete them from the Deleted Items folder you can still recover them. This feature is enabled by default in Outlook 2007 but if you are using 2003 then you'll have to modify System registry.
Enabling recovery of deleted items in Outlook 2003
1. Start Registry Editor(Regedt32.exe).
2. Locate and click the following key in the registry
HKEY_LOCAL_MACHINESOFTWAREMicrosoftExchangeClientOptions
3. On the Edit menu, click Add Value, and then add the following registry value:
Value name: DumpsterAlwaysOn
Data type: DWORD
Value data: 1
4. Close the Registry Editor.
Now when you start Microsoft Outlook 2003 you'll be able to see a new option- Recover Deleted Items in the tools menu.
Recovering deleted items in Outlook 2007:
1. In the folder from where you deleted the item, or in the Deleted Items folder, click
2. Recover Deleted Items on the Tools menu.
Click an item and then click Recover Selected Items
NOTE: If an item doesn't appear in the Recover Deleted Items dialog box then you can't recover it.
on Oct 26, 2010 | Computers & Internet
Tip
WHY DOES OUTLOOK EXPRESS INSIST ON COMPACTING FOLDERS WHEN WE CLOSE IT ?
OE has a long and troubled history with compacting folders. In the most current version, OE compacts all folders automatically after you open and close the program 100 times. Compacting folders is absolutely essential for maintaining your files in good working order. Therefore,
Do not interrupt the process once it has begun
It is best not to use your computer at all until the process is complete, which can take a few minutes.
Under no circumstances must you ever use Task Manager to kill the msimn.exe process, or put your computer on Standby, or turn off the power, or use a memory-intensive program while compaction is occurring. Any of those can cause destruction of your files and the loss of your messages.
If you don't like waiting for that 100th closing, you can compact all folders manually at any time. For best results always use this procedure.
1: On the File menu, click Work Offline so that no new messages will be arriving
2: In the Folder list, click on Outlook Express so that no e-mail or news folder is open.
3: Close the Folder list by clicking the X in the upper right-hand corner of the list panel. Alternatively you can click Layout on the View menu, and then clear the checkbox for "Folder List”.
4: On the File menu, point to Folder, and then click Compact All Folders. Do not use your computer until the process is complete, which might take several minutes.
5: If an error occurs, close Outlook Express, re-open it, and begin the process again from the top. If the same error occurs again, close Outlook Express, restart your computer (or log off and then log on again), open Outlook Express and then begin the whole process again.
Unfortunately that does not reset the internal counter to zero, so OE will still compact after the 100th closing You can edit the registry manually to reset the counter, or you can use OE TOOL to compact all folders and reset the counter at the same time. To reset it manually
1: Close Outlook Express and all message windows.
2: Click Start, click Run and type without quotes "regedit".
3: Navigate to this key
HKEY_CURRENT_USER\Identities\{GUID}\Software\Microsoft\Outlook Express\5.0
where GUID is the long number used for your Identity
4: In the right-hand pane, double-click "Compact Check Count", then change the value to zero(0).
on Jul 03, 2010 | Computers & Internet
I keep getting the message The data file 'personal folders' was not closed properly when I open Outlook, how can I prevent this from happening?
The underlying reason why Outlook displays this "data file" check is very simple. There is a single flag in the header of the data file that is a Boolean value (True or False). While you use Outlook the value of this flag is constantly changing as the data file is updated. When the update begins the value is changed to False and then when the update completes the value is changed back to True (implying the update is finished and successful).
So, the key to the problem is the shut down process because once the Outlook.exe process is exited this flag value cannot be changed. If the Outlook.exe process was terminated prematurely or a 3rd party add-in did not properly set the flag value to True then the flag value can be left at False. If you start Outlook with a data file where the value of the flag is False you are guaranteed to see the "data file" check. If the value of the flag is True then you will not see the "data file" check.
Right now, there are a few known common causes for this issue:
- Shutting down Windows before the Outlook.exe process has exited
- 3rd party add-ins improperly "closing" the data file
- Outlook crashing
- Non-Outlook process accessing the data file
http://support.microsoft.com/kb/954642/en-us
http://support.microsoft.com/kb/948733/en-us
Regarding the post advised by Rod, I would like to explain more detailed:
When you shut down Outlook, the Outlook window goes away, but the Outlook.exe process can continue to run for some time. That's why you can see Outlook.exe sitting in Task Manager for a few minutes after closing the Outlook window. If you shut down Windows while the Outlook.exe process is still running Windows will not wait for the Outlook.exe process to exit. So, you increase the likelihood of encountering the "data file check" issue the next time you start Outlook (because the Outlook.exe process was not able to "close" your data file(s) completely before Windows was shut down).
On the other hand, if you leave Outlook running when you shut down Windows the Outlook.exe process will continue to run and exit on its own. When Windows is shut down, it sends messages to all visible window frames telling them to quit, and will wait for those programs to quit before shutting down. Not until all processes with open windows have exited will Windows finally shut down. This is somewhat counter-intuitive to most people as traditional training has always advised manually closing applications before shutting down Windows.
Mar 10, 2011 | Microsoft Computers & Internet
Links dont open in my Outlook 2007, why?
  1. Click Start, and then click My Computer.
  2. On the Tools menu, click Folder Options.
  3. In the Folder Options dialog box, click the File Types tab.
  4. In the Registered file types list, click (NONE) URL:HyperText Transfer Protocol, and then click Advanced.
  5. In the Edit File Type dialog box, click Edit.
    Important Make sure that you note the current values for the fields that are in this dialog box before you go to the next step. You may have to restore the values for the fields that you changed if this method does not resolve the issue.
  6. In the Action box, type open if it is not already there.
  7. In the Application used to perform action box, type "C:\Program Files\Internet Explorer\iexplore.exe" -nohome if it is not already there.
  8. Click to select the Use DDE check box if it is not already selected.
  9. In the DDE Message box, type "%1",,-1,0,,,, if it is not already there.
  10. In the Application box, type IExplore if it is not already there.
  11. Make sure that there is no value in the DDE Application Not Running box. If there is a value in this box, delete it.
  12. In the Topic box, type WWW_OpenURL if it is not already there.
  13. To close the Edit File Type dialog box, click OK two times.
  14. In the Registered file types list, locate and click (NONE) URL:HyperText Transfer Protocol with Privacy, and then click Advanced.
  15. Repeat steps 5 through 14 by using the (NONE) URL:HyperText Transfer Protocol with Privacy list item instead of the (NONE) URL:HyperText Transfer Protocol list item.
  16. To close the Folder Options dialog box, click OK.
  17. Test a hyperlink from Outlook Express.
hope this helpful
Jan 08, 2011 | Microsoft Office Professional 2007 Full...
Tip
Auto Logon in Windows 2003
Old but nevertheless good. The auto logon can be accomplished by means of Registry modifying, or by use of 3rd-party tools.
To configure auto logon through the Registry follow these steps:
  1. Open Registry Editor.
  2. In Registry Editor, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
  1. Create or modify the following value (REG_SZ):
DefaultUserName
and enter the exact username you'd like to use.
Then, create or modify the following value (REG_SZ):
DefaultPassword
and enter the exact password you'd like to use.
Note: The password is stored in clear text, allowing anyone with access to the registry (either locally or remotely) to see your password. Use with extreme caution!
Next, create or modify the following value (REG_SZ):
AutoAdminLogon
and enter a value of 1.
Finally, create or modify the following value (REG_SZ):
DefaultDomainName
and enter the domain name you wish to logon to.
Note: As always, before making changes to your registry you should always make sure you have a valid backup. In cases where you're supposed to delete or modify keys or values from the registry it is possible to first export that key or value(s) to a .REG file before performing the changes.
  1. Close Registry Editor and reboot the computer.
Note: As far as I know, this trick will NOT work if the user does not have a password. It will only work once, but for subsequent logons it will stop working.
on Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Outlook 2000 inbox
hello
In thsi case try to open outlook in safe mode
the command is
click on start
run
outlook /safe
if that works fine then there is some issue with the addin
then for thsi close outlook
click start
run
regedit
hkey local machine - software -microsoft-office - outlook - under outlook expand addin
then highligfht add in ione by one and on the right hand side modify the regisrt from any other value to 0 , do all thsi with all the addin and then try to open outlook
Mar 06, 2010 | Microsoft Outlook 2000 (543-00638) for PC
Microsoft office outlook, word, excel all stop working-shut down
you can try fixing the problem by diting your registry.
1. go to your desktop.
2. on your keyboard, hit the "windows key" (between ALT an CTRL) together with the "R"
3. a little box should pop up. In the box, type "regedit" and press enter.
4. registry editor should open up. (it looks something like windows explorer)
5. navigate to the following registry key: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Office\ Outlook\ Addins\ Microsoft.VbaAddinForOutlook.1
6. Right click on the "Microsoft.VbaAddinForOutlook.1" and delete it.
7. close registry editor,
8. restart PC and run outlook!
Jun 16, 2009 | Microsoft Computers & Internet
I'm unable to open .eml attachment in Windows Vista.
Here's some info: E-mail message saved by Microsoft Outlook or other e-mail program; may also contain an e-mail attachment, or file sent with the message. Note: If EML files will not open in Outlook Express, try the following:
  1. Open My Computer.
  2. Select Folder Options from the Tools menu.
  3. Click the File Types tab.
  4. Under Registered file types, select EML Outlook Express Mail Message, then click Advanced.
  5. Click Open, then click Edit.
  6. Type the following line in the "Application used to perform action" box:
    "C:\Program Files\Outlook Express\MSIMN.EXE" /eml:%1
  7. Click OK twice, then close the window.
EML files may also be opened in Internet Explorer since they are formatted the same as .MHT files; changing the file extension from ".eml" to ".mht" should cause the file to open directly in Internet Explorer.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Scanner
Hi
I found the solutiom from microsoft
1. On the Start menu, point to All Programs or Programs, point to Accessories, and then click Windows Explorer. 2. In Windows Explorer, edit the file type. To do this, follow these steps, as appropriate for the version of Windows that you are running: • For Microsoft Windows XP or Microsoft Windows Millennium Edition, follow these steps: a. On the Tools menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol under the (NONE) section, and then click Advanced. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2007, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. • For Microsoft Windows 98, follow these steps: a. On the View menu, click Folder Options. b. On the File Types tab, click URL:MailTo Protocol, and then click Edit. c. Under Actions, click Open, and then click Edit. d. If you are running Microsoft Outlook 2002, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office10\OUTLOOK.EXE" -c IPM.Note /m "%1"If you are running Microsoft Office Outlook 2003, type the following text under Application used to perform action: "C:\Program Files\Microsoft Office\Office11\OUTLOOK.EXE" -c IPM.Note /m "%1" e. Click OK two times. 3. In Internet Explorer, verify the e-mail program. To do this, follow these steps: a. On the Tools menu, click Internet Options. b. On the tab, change the default mail program to Outlook Express in the E-mail box, and then click Apply. c. In the E-mail box, change the default mail program back to Outlook, and then click Apply. d. Close the Internet Options dialog box. e. Click Start, click Run, type mailto:, and then click OK.
you can also visit http://support.microsoft.com/kb/312346
Hope this will solve the problem
Jun 04, 2008 | Brother MFC-8460N All-In-One Printer
Palm Zire 31 Handheld Logo
1,420 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
