Question about NetGear MR814 Wireless Router
Can't set it up
I have netgear MR814
I'd like to go wireless, already I have a tiscali broadboad sagemfrost modem that links me to the internet.
I haven't been able to set up my netgear since I brought it.
What i've been doing so far is to type in http://198.162.0.1
it then comes up with the access screen (I have the blue ethernet cable fixed to netgear and comp at this stage) note: that I'm linked up to my normal internet connection.
Then it tries to configure what type of internet connection I have....
after a couple of seconds it says no connection make sure... blah blah blah.
What am I doing wrong that I can't set it up?
  • 29 Answers
First time you have to connect the modem into the router and the router into the computer. run the setup and then remove the cable between the router and computer.
Posted on Aug 31, 2008
MR814 does not get IP address from my ADSL modem
try power cycle modem to clear out the computers onfo then it should connect to the router
Aug 10, 2012 | NetGear MR814 Wireless Router
Netgear MR814 and windows 7 issues
There shouldn't be any issues with the router as a result of Windows 7. The Router does not interact with the computer in such a way as to cause incompatibility like with hardware or software.
That said, what could be causing issues may be out of date WiFi card drivers. Windows 7 has an incredible driver database and I have only come across a handful of things it doesn't detect. But sometimes even with the things it does pick up, a better driver is available.
You should run Windows Update by going to Start (2252758.gif), All Programs, and then Windows Update. If not already set up, you should click change settings on the left and make sure all recommended updates are received like important updates. This way you will get all updates available, including hardware updates.
If this does not seem to improve the situation I will be posting a How To on properly configuring your Netgear router. This will ensure your settings are set to their most optimal settings.
Good Luck,
NOLA Tech
Feb 01, 2010 | NetGear MR814 Wireless Router
I want to use my netgear mr814 wireless router to connect to the internet but i cannot remember the password
which password you don't remember the Router or the Internet account?
if it's the router- you can reset it by clicking on the reset (very hard to find) button.
if it is the Internet password- just call your ISP and have them reset your password.
Dec 28, 2009 | NetGear MR814 Wireless Router
I am trying to get my netgear mr814v2 to connect to the internet via hard wire to comcast with no luck. the connection is good when i go direct from teh computer
If you connect the computer to the modem it works, that means the modem is working.
Now connect the modem and the computer to the router and open the router set up page.
Clone the MAC address of the computer on the router and power cycle the network.
That will work.
Click here
for step by step instructions
Dec 03, 2009 | NetGear MR814 Wireless Router
I can not access my wireless internet network with my new computer. I have a netgear wireless router model MR814v2. I can get onto the internet when directly connected to my modem. However, when I try to...
Hook directly to the router hard wire. Go to configuration page for router and look at wireless security settings. it will show you Wep or some other encryption technique. It will also give you a place to view or change your wireless key. Once you do that write the key down and then connect wirelessly.
Nov 08, 2009 | NetGear MR814 Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Belkin N1 Wireless Modem Router I cannot connect to Tiscali HELP
I had this with Bt Internet and this exact same router, you have to phone Belkin up and they give you a complete set of new settings that you manually have to put in during setup. If i remember rightly its a free phone number and the operator who answered spoke semi-english so not all bad, hope this helps.
Chris E
May 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Netgear MR814 won;t connect
wireless problem is there re-configure the wireless router go to the wireless option then cilk right information then you get it
Mar 04, 2009 | NetGear MR814 Wireless Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Setting up netgear dg834gmodem router
u will need to call netgear get your isp or ther dns server codes they will tell u it and u will enetr in the network adpoters properties area ok thx nick
Mar 13, 2008 | NetGear DG834G Router
NetGear MR814 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
