Question about Dell Latitude D600 Notebook
C/windows/system32/ parameter incorrect at the startup. Hitting 'ok' wouldn't work out either.. what to do.. and yeah i ran spybot in the safe mode when this happened on the subsequent restart!! Any help will be really appreciated!! Regards, Ronald!
    Problem Solver:
  • 15 Answers
This worked for me after the others didn't, get REG cure and fix your system, it seems weird to fix a virus remover with a virus remover but it works and I'm only 11!
Posted on May 31, 2009
  • 300 Answers
That sounds more like a virus infection to me. I would suggested downloading and install Avast antivirus from
Once you get it downloaded just double click the file to start installation.
NOTE: You will need to remove whatever antivirus program that you have now before installing Avast
During the installation you can just accept all defaults and choose yes on the boot time scan. Once computer restarts it should automatically start the scan.
I hope this helps. Please remember to rate this information.
Posted on Aug 31, 2008
  • 264 Answers
It seems that spy sweeper has removed some spywares from the start up.
You need to click Start>Run> type "MSCONFIG" without quotes>Click OK
You get the window on the top click Startup
See in this list if you have a file with name
Uncheck the same. Apply the settings and restart the computer.
You may get a messege that you have used the system config utility......
Check "Do not show this messege sgain and click OK.
Good Luck
  • Sameer Kashyap Aug 31, 2008
    ***I wanted to say spybot instead of spy sweeper***
Actually is invoked by Spybot - it wants to remove the remaining files but can't. Here's how to fix it:
Get into regedit (Start -> run -> tye 'regedit' (no quotes), hit enter).
Go to:
In there you will see some Spybot entries (possibly a lot of them!) - delete them all and reboot.
This fixed my problem.
Posted on Sep 16, 2008
  • 1 more comment
  • kizzell95 May 29, 2011
    Thanx heaps for that... But now everytime I start up windows all this black screens keep popping up
  • bvdijk Jun 09, 2011
    Thanks for this tip. In my case this was the result of using latest Spybot beta version to delete malware
  • andywmorris Jul 15, 2011
    Problem arose using latest spybot beta version - excellent advice - worked a treat - was then able to uninstall the spybot programme
Can not find Scriptfile "C:\WINDOWS\System32\System32.db".
This is most likely the leftover startup command of a deleted virus. Run your antivirus again, or if that doesn't solve the will need to work on your startup file. Be careful in here as things can get hairy. Go to Start > Run and type msconfig
Go to the startup tab look for a line that contains C:\WINDOWS\System32\System32.db in the path. Clear the checkbox next to any programs with this path and then click ok to save. You will probably have to reboot after doing this.11_20_2012_3_54_12_pm.gif
Nov 20, 2012 | Dell Latitude D600 Intel Pentium M 1.3GHz...
After clicking user name on Windows XP welcome screen error message appears: C:\Windows\System32\ parameter is incorrect. Clicking OK does not close the error message. Desktop does not appear,...
Try starting up in safe mode keep tapping f8 untill the advanced start menu comes up
login as administrator
press start -> run -> type in the run menu: msconfig and press enter
in msconfig open the startup tab and click disable all, apply and ok, restart normal mode. should work fine.
Aug 11, 2008 | Computers & Internet
When start system show error
Does the system boot up? This does not seem like an error that would stop it from booting up, just an annoyance.
Click Start/Programs and look for the RUNcommand. You might see it anywhere once you click Programs, or it might beinside the Accessories folder. Click RUN and when it opens up type"msconfig.exe" (without the quotes) then hit ok.
When the System Configuration window opens click the Startup tab. In theStartup Tab we are only concerned with 2 columns, the first column which is theStartup Items and the column that says Command. You can put your mouse pointerbetween two column headings and it will turn into a +, then hold the left mousebutton and drag the column over to the right to expand it so you can readwhat's below it.
Now everything has a check mark beside it. This means that everytime youstart your computer, these items have to load and run.
Start with the first item listed under the startup item column and look at itand look at the command for it. We want to find the command that your system is having a problem with the script file. The command is C:\WINDOWS\system32\FAantivirus.vbs. When you see it under the command column take the check mark off over to the left next to the item column and this will keep it from running the next time you boot your system.
May 07, 2012 | HP Desktop Computers - Hewlett-Packard...
How do i clean c:\windows\system32\ parameter incorrect cant seam to get past boot up
Try doing a Windows repair by booting off the recovery disks or Windows CD
Jun 29, 2011 | Dell Latitude D600 Notebook
Hi ,I have HP Pav DV6 with windows 7.But I want to install windows server 2003 & its not allowing me.I want to make it dual boot,Plzz help.I need to do it urgently...
Please understand that Windows 7 uses different startup files and procedures so it is expected that the original Windows Windows 7 system cannot be booted if you install a new dual boot Windows Server 2003 system. If you would like to install Windows Server 2003 on another partition, please do that first. After that, Windows Server 2003 will boot but WIndows 7 not. However, we can try the following method to make Windows Vista work again: Insert the Windows 7 disk into DVD-ROM. Click Start, click Accessories, right-click the command-prompt shortcut, and then click Run as Administrator. Type the following command at a command prompt and press Enter: Drive:\boot\Bootsect.exe /NT60 All In this command, Drive is the drive where the Windows 7 installation media is located. Note The boot folder for this step is on the DVD drive. 4. type the following commands at a command prompt and press Enter. Note In the commands below, Drive is the drive where Windows 7 is installed. Drive:\Windows\system32\Bcdedit /create {ntldr} /d "Windows Server 2003" Drive:\Windows\system32\Bcdedit /set {ntldr} device partition=x: (Note: x: is the drive letter for the active partition. For example, if 2003 is installed on C drive, device partition=c: ) Drive:\Windows\system32\Bcdedit /set {ntldr} path \ntldr Drive:\Windows\system32\Bcdedit /displayorder {ntldr} /addlast
5. Restart the computer.
Jun 08, 2011 | Computers & Internet
I run a spybot programme to sort my7 laptop and
the file on this root is missing, u will have to replace this file. probably by reinstalling the operating system. the program probably deleted it, (must be infected)
Apr 16, 2010 | Dell Latitude D600 Notebook
I can't install a visual basic 6.0. because I've been accidentally deleted the some components of system32. most especially the config.nt
If my memory serves, VB 6 was the last dos/windows version and windows;nt was simply a text file that held some config parameters when it ran in nt mode. I woud suggest you update your software, but if you are unable to do that, you might try reloading nt from diskette or CD. I think NT also supported the undelete command. If it hasn't been very long since you erased it, you may be able to restore it with an undelete. I think that was the command name.
Dec 11, 2009 | Microsoft Windows XP Home Edition
Installing yahoo messenger incorrect command line parameters
why cant i send a message to all my friends on yahoo messenger?how can i solve this?
Jul 02, 2009 | Yahoo Messenger
do it
Use the Windows 2000 CD-ROM or the Windows 2000 Startup disk to start the computer. 2. When you see the "Welcome to Setup" message, press R for "repair." 3. Press C to run the Recovery Console tool. 4. Select the installation that you want to repair. 5. Type the administrator password.
If the computer is a domain controller, type the password for Directory Services Restore Mode when you are prompted to do so.For additional information about the Recovery Console tool, click the article numbers below to view the articles in the Microsoft Knowledge Base: 239803 ( How to Change the Recovery Console Administrator Password on a Domain Controller 223301 ( Protection of the Administrator Account in the Offline SAM 6. At the Recovery Console command prompt, type the following commands, pressing ENTER after you type each command: cd system32\config
ren system system.old
ren system.alt systemalt.old
7. If you have run the Emergency Repair Disk Wizard from Windows Backup and Recovery tools, copy the backup of the System hive from the %SystemRoot%\Repair\Regback folder.
If you have not run the Emergency Repair Disk Wizard, copy the default System hive from the %SystemRoot%\Repair folder.
IMPORTANT: You need to restore the most recent copy of the System hive. You also need to reinstall any hardware device drivers or programs that run as services that you installed since the last time that you updated your Emergency Repair Disk.
To copy the default System hive, type the following command, and then press ENTER: copy c:\winnt\repair\system c:\winnt\system32\config To copy the System hive that was backed up the last time that you ran the Emergency Repair Disk Wizard, type the following command, and then press ENTER: copy c:\winnt\repair\regback\system c:\winnt\system32\config 8. At the command prompt, type exit, and then press ENTER to restart your computer.
Jun 23, 2008 | Compaq Presario 1200 Notebook
Pssword lock out
If you still can't find the solution try this thread:
Oct 09, 2007 | Microsoft Windows XP Professional With...
Dell Latitude D600 Notebook Logo
9,569 people viewed this question
Alun Cox
