Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
Help!! Our unit is draining on the inside and dripping on the floor, it has stopped draining outside. We have been running the ceiling fan a little while unit was running I do not know if that had something to do with the problem. Thanks, Debbie
  • Anonymous Mar 12, 2014
    The Midea MSC-21HRN1 is dripping, how do you drain the unit?
    Champion:
  • 254 Answers
Looks like your condensate line has either come loose, or it may have a restriction in the line somewhere.
Posted on Aug 31, 2008
My 18000 unit running water back in the unit on my floor.
The condensate drain to the outside is most likely stopped up.
See if the unit is dripping to the outside.
If not, you should be able to see where it has been dripping out in the past and unplug the hole.
Sep 19, 2017 | Heating & Cooling
My Kenmore window ac unit cools ok but makes a clicking/clacking sound while it runs. The cooling fan turns properly and it drains outside but has started to drain a little inside-it is angled to drain...
From everything you described, it sounds like more water than usual is collecting in the drip fan. Despite the unit draining out the rear drain hole. Check the drain hole to make sure it is totally clear and not partially clogged. A pipe cleaner works well to do this. Be sure to turn the unit OFF & unplug it, before working on it.
Hope this helped you and tanks for choosing FixYa.
Aug 15, 2011 | Kenmore 76100 Wall/Window Air Conditioner
Whirlpool Refrigerator model EHT-201VK is leaking water inside and outside.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Sep 28, 2010 | Whirlpool Refrigerators
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Kenmore fridge is leaking inside from light switch
The drip pan is underneath on the floor. You don't really need to see it. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 18, 2009 | Refrigerators
Kenmore refrigerator (model 106.78187891) leaking inside
Aug 14, 2009 | Refrigerators
I have a unit in the attic and another part outside. I can stand inside under the ceiling vent and hear water running. When the unit cuts off, the water sound quits. I'm afraid something is not draining...
Sounds like your drain has sagged from the heat in the attic. It then backs up in the pan and sloshes around from the air moving. Get up there and see if that is the case, if so support the drain line so water runs freely to outside. This is an experienced guess. Good luck!
Aug 04, 2009 | Heating & Cooling
My walk-in's ceiling panel is dripping
The coil in the conditioned space is called the evaporator.
If the water droplets are forming on the ceiling around the evap, it is due, most likely, to the defrost cycle being too long.
Defrost cycle: compressor stops, evap fans stop, electric heaters in the evap come on to clear any ice/ frost on evap fins/ coil.
The ice/ frost melts and some of it turns into vapor. As it hits the cold ceiling surface, it condensates into water droplets. Defrost cycle could be too long. Usually 4 time aday and no longer than 30 minutes should be enough unless there is high humidity.
There could be another cause.
Normally, after a defrost cycle terminates, the evap fans do not come on, due to a delay control. This prevents circulating warm are due to the heaters. The compressor comes on and cools the evap down to, usually 20 degrees or so, and then the fans come on. What could be happening is, the fans are coming on too early and blowing the water driplet off the evap and onto the back wall of the unit.
A third item, is to be sure that the condensate drain is "P" trapped. The prevents warm, outside air from being drawn in and causing exess frost build up, thus excess water and vapor.
Good luck and hope this helps
Jul 24, 2009 | Nor-Lake Freezer Norlake Refrigeration 8'...
Wet on Passenger side floor when AC is on
Auto ac units have an outside drain for the condensation. If you ever noticed a car running and it looks like it's leaking something on a hot day it's the condensed water from the ac unit draining. What you have is a clogged or disconnected drain hose.
You need to find the hose and drain and reconnect them. Sounds simple, good luck.
May 08, 2009 | 2005 Dodge Grand Caravan
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
115 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
