RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Posted on Aug 31, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
3 screens there are 3 screens playing all at once
Sonny Berry
Level 3:
  • RCA Master 8,617 Answers
  • Posted on Aug 31, 2008
Sonny Berry
RCA Master
Level 3:
Answers
8617
Questions
Helped
1723301
Points
23750
You need the ITC222 Convergence power supply board. You can get a replacement at the following link.
http://servicemanuals.vstore.ca/
Roku com support
If you're referring to xfinity router and you're getting error code 014, try to do the following:
On your Roku remote, press the following:
Home button 5x
FF once
PLay/Pause once
Rew once
PLay/Pause once
FF once
It should take your to the platform screen. Check if there's an IP address, a valid Ip address which is not all zeros. Then look for Disable NetWork Ping and press ok on it. Then go back to the Home screen then reconnect to your network.
3helpful
Download google play
Go to the play store which is located under apps. Click on that and wait for that to load and there should be a search bar. Press the search bar with your finger. It should then bring up the keyboard on your screen. Type in Google play and then hit search or enter. Google play should come up and then click the download button next to the app. Once the app is downloaded it should say download complete. Then the app will be visible on your main screen and is also accessible from your apps screen.
1helpful
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
Bought Lips recently and played it fine first
The game was released broken. There is an update on xbox live that fixes it. So you pay twice, once for the game and once for xbox live. If you don't have xbox live or no internet you simply can't play. In other words you got robbed. Nice scam huh?
Starting not to read and play mp3 discs, only had for 2 years
Get a cleaning CD and clean the head, needs to be done once 1-2 month
1helpful
Dell XPS M1710 Laptop Screen Flashing In Full Screen Gaming
Y DON,T YOU CHANGE UR RESOLUTION IN GAMES SETTIGS OR CHANGE FROM URVIDEO DRIVER INSTALLED TO UR PC
1helpful
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Panasonic DVD-S47
If you still have a warranty on the Dvd recorder send it in for Repair.It's either a Factory Defect or a sort in the control switch.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
