Mitsubishi air conditioner MWH-35EB-A3
It's 20+years old & still going strong!! Can anyone give me the specifications of it? Specialy the cooling & heating capacity in BTU's?
(Mitsubishi air conditioner MWH-35EB-A3)
Thanks
zinzos87@netbay.com.au
  • zinzos87 Sep 01, 2008
    I did checked it & I got the Info.
    Thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check the webpage for manufacture specs!
Posted on Sep 01, 2008
Im trying to find out how to get fault codes up on our mitsubishi remote control. the unit is 4 years old
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals forall of the Mitsubishi line. The manual include both troubleshooting andinstallation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 15, 2011 | Mitsubishi Heating & Cooling
Mitsubishi msz-ga60va not cooling. Did same last year then righted itself. Left light is flashing. and no cool air. Please help.
You didn't give any error code. But, still, I hope unit need complete service. Do it and check again.
Jan 07, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Our reverse cycle airconditioner is not cooling in two of our bedrooms, but the rest of the house seems to be cooling alright, but I am sorry the airconditioner is approximately 6-7 years old and we have...
Hi, I assume it is ducted, it could be either a flapper door is closed to shut off an area from receiving air, or there is a blockage in the duct (less likely). Also if there is more than one duct attached to the air conditioner then you'll have to check if air is entering all ducts (you may have a problem with the unit).
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Through the Wall Unit Does Not Remove Humidity
You were told incorectly. From what you are describing the unit is oversized for your space.
All Air conditioners remove humidity. In fact the Air conditioner was invented by accedent by Mr carrier when he was trying to invent a machine to remove humidity. He discovered that by drawing air accross a cold coil the humidity drained off the coil. He also discovered that it was a mighty effective way to cool large quantities of air, and we then had "Carrier" air conditioning systems.
When a system is to large for the area it is to cool, it will cool the air in that small area so fast that the humidity starts to condense in the room before it can be pulled through the evaprator coil.
In this case, the solution would to be either replace the unit with a smaller one.
Increase the area to be cooled. (open doors to other rooms etc). or use the dehumidifier.
How many square foot is the space you are trying to cool?
What size is the AC unit? (in "tons")
Aug 25, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
When the control is set on air conditioning, it has recently started to dehumidify also on that setting. What to do? The unit is 5 years old.
I'm sorry is the unit set on COOL (snowflake) or DRY (raindrop) All air conditioner will dehumidify when in cooling mode. That is just the dynamics of air conditioning. The air should still be cool depending on your settings. if the air is not cool and you have confirmed that it is in cooling mode, check that the filters are clean and if they are have the system serviced.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Squirrel cage installation.
If there is strong air flow blowing into the house the sq. cage should be OK. Possibly you need to replace the pads and make sure that the pump is not clogged and is distributing enough water to keep the pads wet.
May 05, 2009 | Mastercool 67680 Evaporative Cooler Air...
Smell from Mitsubishi air conditioner
THE SMELL MIGHT BE FROM MOLD DUE TO HUMIDITY COLLECTING INSIDE THE UNIT NORMALY THE GAS A A/C USES IS ODERLESS OR MIGHT BE FROM STAGNET WATER INSIDE THE UNIT.
Mar 09, 2009 | Heating & Cooling
Older roof mount RV Colman Air Conditioner on a 1989 Motorhome(class C)
It depends how old it is most can be regased but about 15 or so years ago they changed refrigerant gases because the old one was killing the ozone if not that old you should have no problems with regasing it just make sure they check for gas leaks first which is a small amount of dye put in the gas so you can see the leak. Hope this helps
Jul 22, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
