I have just purchased a Tungston E2 to replace a Tungston T2 and want to transfer the information from the T2 to the E2 but have not found a way to do this through the HotSync process.Is there a direct way to do this?
  • lynandneil Aug 31, 2008
    Before instituting your advice I gave the E2 a new user name as the old user name could not be applied to the new E2.Now I can't find a way to change the user name on the E2 to be the same as the existing one on the T2
  • 435 Answers
Many factors can influence synchronization. We'll take you through astep-by-step diagnosis to resolve the most common issues. If you needhelp synchronizing for the first time, see your Palm device's userguide.
These steps will work ONLY with the HotSync software provided by Palm.If you use third-party synchronization software (IntelliSync, iSync,Missing Sync, etc.), contact the third-party developer for assistance.
For more information on Hot Sync Troubleshooting, please refer:
HotSync Troubleshooting Guide
Thanks
Posted on Aug 31, 2008
  • 2,071 Answers
  • LORETO LACARON
    LORETO LACARON Sep 07, 2008
    Did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further.
  • 13,433 Answers
You need to hotsync your old pda, it creates a backup of the data, then you need to change the hotsync settings so that it replaces all the contents on the pda instead of backing up. This way you will get your hotsync backup into the new pda.
  • 1,879 Answers
Nope, there's no way to HotSync direct. Just follow coolguy008's instruction.
  • 6,487 Answers
The easiest way to transfer data is to hotsync to a desktop PC. First, install the proper Palm Desktop and Hotsync manager software by going to http://www.palm.com/us/support/palmdesktop.html. Once the software is installed properly, connect you OLD Tugnsten to your computer by using the sync cable that came with the device. You may need to press the hotsync button on the cable that connects to your device. This will begin the hotsync process and transfer all your data from your device to your PC. Now your PC and old tungsten share the same information.
Next you need to connect you NEW Tungsten to your computer and sync to the existing username you created during installation. This will then make the PC and the NEW device share the same information. You should be done at that point and your new PDA will have the data now.
You can use Palm Desktop to add, remove, or edit any information and sync the changes to your device.
Hope that helps.................
  • Mark Gil
    Mark Gil Aug 31, 2008
    Try first to change the user name follow this:
    Changing the user name on your device and assigning a new one at the next HotSync operation may resolve certain HotSync difficulties. If you have two devices synchronizing to the same computer, they must have different user names.
    Changing your user name
    1. On your desktop computer, launch Palm Desktop (even if you synchronize with Outlook or another application).
    2. Select Edit Users from the drop-down list of user names.
    3. Select the name you want to edit and click the Rename button.
    4. The new name will be written to the handheld during the next synchronization
    Good luck.........
    Genius:
  • 3,422 Answers
HI,
The easiest way to transfer data is to hotsync to a desktop PC. First, install the proper Palm Desktop and Hotsync manager software by going to http://www.palm.com/us/support/palmdesktop.html. Once the software is installed properly, connect you OLD Tugnsten to your computer by using the sync cable that came with the device. You may need to press the hotsync button on the cable that connects to your device. This will begin the hotsync process and transfer all your data (that you choose) from your device to your PC. Now your PC and old tungsten share the same information.
Next, you will want to connect you NEW Tungsten to your computer and sync to the existing username you created during installation. This will then make the PC and the NEW device share the same information. You should be done at that point and your new PDA will have the data now.
  • Priya darshan Aug 31, 2008
    This is the only way to do it.There are no more home remedies.
I want to transfer the information from palm desktop on a PC to Mac OSX. The palm tungsten e2 is water damaged and not working.
Inside the PalmOne forlder in Program Files, find a folder that is named the same as you Hotsync ID. A flash drive would be the best idea to transfer the files over to the Mac. Some flash drives don't work on Macs, so try a few.
Jan 18, 2010 | Palm Tungsten E2 Handheld
Battery not holding charge
Don't got to the Palm store. Go to EBAY. 4 years is a fair longevity for your battery.
Jan 06, 2009 | Palm Tungsten E2 Handheld
How to load real player on the e and repair e2
RealPlayer for Palm runs on the latest Palm-branded OS 5 devices with ARM processors. It supports the local playback of MP3 and RealAudio content from inserted SD memory cards. The RealPlayer for Palm currently supports the following Palm PDAs:
clear.gif clear.gif clear.gif bullet.gif Tungsten T, T2, T3, and C clear.gif clear.gif bullet.gif Zire 31, 71, and 72 clear.gif clear.gif bullet.gif Treo 600 Additional information is available here:
http://www.realnetworks.com/industries/mobile/products/player/palm/index.html
Jan 05, 2009 | Computers & Internet
Tungston E2
1. Upper left corner press time
2. Select delete
3. Pick program you loaded
4. press delete
Oct 07, 2008 | Palm Tungsten E2 Handheld
Tungsten t2 oem install cd
As far as I know, the general tungsten e2 program works on most. It can be purchased from palm. Now I wish I could sell mine
May 08, 2008 | Palm Tungsten T2 Handheld
Just bought a Tungston E2 and installed it on myPC. I can't get Hotsync to install my palm desktop info. (Calendar/contacts/memos/doc. to go/etc)on to the handheld. I was successful in installing the...
The problem is still not solved, but I have turned it over to the group that handles equipment under warranty (which mine, being only one week old, is). Instead of paying for your services, I should have been told the other number to call. I request that there be no charge for the time you spent with me. Brooks Goldman
Mar 28, 2008 | RIM BlackBerry Pearl 8100
Haier HWM5TL E2
I looked at the Haier website and all other usual sources but could find nothing. I think you should e-mail service@haier.com.au with the same query. Good luck
Sep 30, 2007 | Washing Machines
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
