Question about Olympus D-460 Zoom Digital Camera
"Card Full" Images printed at Wal-Mart. Unable to remove from card. Images downloaded to laptop...formatted from computer. Insert card in camera...can't take pictures, display reads, "Card Full". Format attempted in camera...ends up with "No Images" indicating format is successful. Still can't take pictures...display says "Card Full" Not my camera. It belongs to elderly uncle who expects me to "fix" his camera! Please help.
  • DearDunn Aug 31, 2008
    the card was formatted in FAT32 Any other suggestions
    Novelist:
  • 72 Answers
My answer:
Your 2000 model year Olympus D-460 Zoom DigitalCamera, that is now possibly going on 8 years old (not sure when youbought it), may not only be having memory card problems so much as it(camera itself) may just be plain tired/worn out period. After all - itmay very well be 8 years old! That is a long time running for anydigital camera!! Olympus included!
First of all - You are hopefully using one of the following SM memorycard sizes in your camera: Removable 2, 4, 8, 16, 32 or 64MB 3V (3.3V)SmartMedia (SSFDC) Cards? I hope so as only these above listed SM sizecards will work in your camera! Anything larger then a 64MB card willnot work, as the camera BIOS chip will not even recognize it at best orsecondly will not even read/write it properly. AND - even if it were totry - the pix saved on it would never be properly (E2PROM) or EEPROM(Electrically Erasable Programmable Read-Only Memory) saved, and wouldnever be able to be fully retrieved properly!! This I KNOW FOR A FACT!!There has to be power to the memory card first before it will doanything - READ or WRITE!! Thus the EE part of the term E2PROM.
(One Olympus 8MB SM card including Panorama function was initially supplied with your camera as well)
Are you still using that same original 8MB card by chance?? Or are youusing a larger SM card no larger then 64MB? If you are still using thatoriginal 8MB card then I can already see a few possible causes offormatting problems you are having there.
First being - Are the electrical GOLD contact strips on that card youare using at present very dirty & tarnished or DULL looking, asopposed to being a very BRIGHT GOLD COLOR? If they are tarnished (verydull looking), and if you handle the SM card(s) (or any memory cards for that matter) improperly - then that is your problem INDEED rightthere, or at least HALF your problem as it were. If you touch these(real Gold btw) electronic contacts time and time again then they willtarnish and cause parity writing problems (bad memory bits) to thecard. Esp writing problems - as the Read part goes hand and hand as itwere! This again I KNOW for FACT!
When the camera writes bad data (bits) to the memory cards, not onlydoes it store that bad data (bits) everywhere throughout the card, butit is written much like that of a "straight line effect" in that if onebit is bad then the entire line - as it were - is bad as well, andnothing wants to be read back properly!!
Secondly - Same goes for an internally bad memory card as well - inthat - if any one bit of storage space inside the card itself goes bad- then the whole card is bad. Nature of the design with EEPROM designedmemory cards. Rarely does this latter case scenario happen, but itcould with abuse to the card (ie: exposure to excessive heat, excessivebending of the card to any degree, etc)
If your SM card even has ever been forcefully bent while inserting itimproperly into the camera memory slot (whether improperly angled orreversed side in) then chances are some irreversible damage has beendone to it, and time will only tell if it totally fails initially orsomewhere down the road. That is part why the thinner (more prone tobending) style SM cards were phased out to begin with, and replaced bymuch thicker/stiffer, and much stronger cards like the XD cards forinstance.
Here are some very important DOS & DON'TS where SM or XD memory cards are concerned:
Please read what I'm posting below for asimilar XD mem card problem, as I firmly know you are "formatting"your SM card improperly using your home computer instead of"formatting" the card in your camera, regardless of what cmptr OS you are using.
Most early model Olympus digital cameras would only use the CAMEDIAsupplied software that came along with that camera, and ran excellentwith WIN98SE & WIN2000 OS whether using a USB Card Reader or elsedownloading directly from the camera using the USB adapter cablesupplied with the camera. If you are now using XP (or even worse yetVista) and you have any driver issues with your XP at present - thenthat is your 1st priority to clean that up first. Everything else priorsaid above being secondary!
Also the SM type card & size are very important as well!!
What you will have to do is read and download the photos you have/hadonthat SM card using the same CAMEDIA software and/or WIN98SE or WIN2000with or without a "card reader" you may have used before, and thenproperly "re-format" that card in your "CAMERA ONLY". This WILL solveyour SM card problems.
Also -
1st - If you have an older Olympus camera morethen 4-5 years old the newer M & H series XD type cards over 256MBwill probably not work in your older camera, as by the camera'sinternal BIOS firmware chip design of the camera itself. Some cameras wereupgradeable some weren't as to the internal firmware chip, as well asavailable software drivers depending on which computer OS system youwere using ie: (WIN98SE, WIN2000, etc). Has to do with the memory cardread/write chip speed as well, and also has to do with the physicalstorage size of the card itself. Some digital cameras were MAXED OUT with512MB cards, some as low as 256MB. At that point a 2gb card simple won't work inthat/your camera in that case.
If you read the camera's user manual it will possibly tell you this, orelse go online to www.olympusamerica.com and use this link:
Viewwhich cameras are compatible
Select camera model series and scroll down the model # and research themax card size & type you can use (3 basic XD card speed typesavailable - regular XD - M type - H type).
If you are using the wrong type & size card you will need to returnthat card (if you can) and get the right XD size & type for yourcamera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes onmost Olympus cameras) the new card, or any SM/XD card for that matter inyour camera itself. NOT THE HOME COMPUTER!!! The 2 format proceduresare not the same!!
If you are re-shooting (re-using) the same XD card over and over againand then downloading the JPEG pix directly to the computer using a USBinterface cable there usually is no need to re-format the card again aslong as the XD card stays the camera and is not downloaded into a homecomputer via say a "card reader". If you do the latter "card reader" then Iwould advise doing a card re-format in the camera again just to besafe!!
And lastly - If your home computer recognizes the XD card via a good"card reader" (do not FORMAT the XD card here btw, as you are justchecking the card out to see if it is GOOD is all), but the camera willnot then that is a good sign your camera is OK, but it's just the wrongtype & size XD card.
Hope this helps solve your camera SM/XD problems past to present regardless which modelyou have.
See the following camera example info for your specific model at the link belowunder Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
Best regards,
Frank
Posted on Sep 01, 2008
    Master:
  • 397 Answers
Try putting the card back in the laptop and formatting it FAT32 and not NTFS. Some cameras are not able to read the NTFS file system.
Posted on Aug 31, 2008
  • Richard Finch Aug 31, 2008
    With the card in the laptop, right click My Computer, select Manage from the drop down list, then in the new window select Disk Management.
    Does the card show up as a drive?
    Is it basic or dynamic?
    It's begining to sound like the card is faulty.
How do I download images from my surveillance camera?
You say you have 'activated SD format'. This probably means you have formatted the SD card, thus erasing all the images from it. To download images in the future, remove the SD card from the camera and insert it in a USB card reader attached to your computer.
Aug 23, 2016 | Cameras
Memory card is full and when I plug in the USB cord and turn on the camera I get a message that my device is not connected or is busy, or that it contains no pictures!!
Causes of memory card corruption
  • Turning off a camera before an image is completely written to the memory card.
  • Removing the memory card from a camera while an image is being written to the card.
  • Removing the card from a memory card reader while files are still being transferred to a computer.
  • Batteries conking out as files are being transfered directly from the camera to a computer. Note: always make sure you have fully charged batteries before transferring images.
  • Removing the card from a card reader while folders and files from the card are open on a computer.
  • Opening, deleting, renaming or moving files on the card while its contents are open on a computer.
  • Using a memory card which has not been formatted in the camera. Use the delete/erase function when needed, however a card should be regularly formatted.
  • Formatting a card in a computer instead of the camera.
  • Inserting a second memory card into a card reader before closing and removing the first when viewing images on the card from a computer.
  • Taking photos when camera batteries are nearly empty.
  • Taking photos too rapidly so the camera can not complete writing one image before starting the next.
  • Continually shooting and deleting, shooting and deleting images when the card is full.
  • Letting a memory card get too full before downloading the images to a computer or storage device. Cards that are too full may overwrite the card headers.
  • Using a memory card from one camera in a different camera without formatting it in the new camera first.
Feb 28, 2008 | Cameras
Unable to see photos tarn half way through this card
Not necessarily. Can you download the images from the card reader in you computer If you can then do that THEN format the card
Sep 15, 2015 | Cameras
Camera is saving on memory card?
Take everything back to Wal-Mart and try again.
Sep 23, 2012 | Kodak EasyShare CD40 Digital Camera
How to get photos developed from a mobile phone
If you have a removable memory card they can do it at the photo computers at Wal-mart. If you don't have a removable memory card then you will have to get a USB cord that hooks to your phone and develop them at Wal-mart.
Apr 05, 2011 | Lands Phones
I have a Panasonic Lumix DMC-ZS1. Once I transfer the media cards pictures onto the computer and then re-insert the card into the camera, all pictures seem to have been deleted. However, when I take the...
When you remove the card from the computer, do you use the "safely remove hardware" function? If you don't, the card can become corrupted enough that your camera no longer recognizes it.
Apr 26, 2010 | Panasonic DMC-ZS1 Digital Camera
I have images on my card, but my Canon EOS Rebel 300D says "no images in the camera or card folder" how can I get them to download. Will they download at a Wal-Mart card reader?
look very carefully at the pins inside the socket.. you might have a bent or broken pin making the camera unable to read the card. Also, if the images on your card are not Jpg or CanonRAW, the camera won't recognize them.
Feb 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Card error
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering images.
Feb 12, 2009 | Olympus FE-170 Digital Camera
Card cannot be used
This means that the card memory can not be read, make sure the contacts are, clean. use pressurized air cans available from most places like, Wal-Mart, Best Buy, Staples, etc.
lightly blow out the memory card and the camera slot, check pin alignment, Format the memory card on your computer first and re-insert in camera. Use another card to see if error continues.
Mar 14, 2008 | Nikon Coolpix 4300 Digital Camera
Olympus D-460 Zoom Digital Camera Logo
260 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
