Either spend $40 to buy a new CD/DVD reader/writer,
or take the CD-ROM with the files to another computer.
Spend $10 to buy a 4Gbyte USB memory-stick.
On the other computer, copy all the files from the CD-ROM disk to the memory-stick.
Move the memory-stick to your computer, and install from the files now on the memory-stick.
hope this helps
hope this helps you
Click start control panel administrive tools computer
management device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device or scroll to dvd regions select
the no _ for your specific area
If this does not fix the
problem you might try
Click start control
panel administrive tools,computer management,device manager scroll down cd-dvd
rom drives you might see a yellow question mark ? right click you will
have options to update driver,roll back driver,or select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall if this does not fix the problem it might be
a registry problem if you cant see your disk drive in windows explorer
Close all open
programs
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug
them back this should activate the found new hardware wizard or
you might have to uninstall
then restart your computer then reinstall your DVD/CD then reinstall the driver
for this device
if your computer came with
a motherboard disk the drivers could be on it
click start control panel
administrive tools computer management device manager scroll down cd dvdrom
drives if you see a yellow question or exclamation mark?! or a red x
right click you will need to update the driver
or
select properties general troubleshoot, select driver
click to reinstall drivers click update driver
hope this helps
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
