Question about Sony Handycam DCR-DVD105 DVD Camcorder
DCR DVD 405
The problem i am facing is that i recorded a brand new DVD and before finalize i get the following message disc error unsupported format.
Please give me some help because i do not want to loose all my data already recorded
Regards
  • 5 more comments
  • leodor Aug 31, 2008
    i was using a compatible DVD its is TDK DVD RW
    when i recorded i had the chance to review all the things i was shooting and ecerything was o.k. After coming bvack from my vacations i found this problem. All in one: the dvd is compatible but the camera cannot recognise it!
    i put the dvd in to me pc dvd recorder. THE PC cannot read it!
    sure its ia faulty disc what can i do?
    are you sure that i wont loose al my data???
    up to now there is no solution
    DEAR VOTIT
    The onl thing i can do is to reformat the DVD.
    I am afraud that if i will FORMAT i will lose all data. is it any way to create a duplicate of the DVD. I tried NERO but it cannot open the DVD. Neither NERO nor Windows Explorer can read the dvd
    tech expert
    what do you mean give me some hints
  • Sony Master
  • 2,794 Answers
Are you using DVD+R or DVD-R?
Posted on Aug 31, 2008
    Master:
  • 521 Answers
Technical at your place is much necessart .as he would be having all the data recovery software disc.and will not make your data clear up from the disc.as formatting or doing anything else in wrong way will make the data corrupted.the engineers have the data recovery tools and software.it will definately help.
thanks.
  • tech expert12 Aug 31, 2008
    there are softwares which save a back up of data before reformating the device.so as to save all the data without losing any of it.so that u can format ur device without any hassles.
    thanks.
    pls do rate the solution.
    regards,
    fixya expert team.
    so its advisable to contact a technician who can back up and then reformat
  • 2,071 Answers
The DVD could be corrupted that's why your computer won' read it. Refinalize it and see what happens. Make sure your'e using came from the electrical outlet and not the battery when your doing it.
hope this may help;
Regards,
VOTIT
  • LORETO LACARON
    LORETO LACARON Sep 07, 2008
    bring it to sony service center and ask an advice what to do,they know better there...
    good luck..
    Guru:
  • 1,894 Answers
You told you PC cant read this disc.
yes absolutely correct. PC cannot read disk which have not been burned successfully.
but there are software by which you can get your data back.
ISOBUSTER is the best one.
get a free version from download.com
if you need help regarding this then please post back with my name.
also you cannot get this problem solved unless your camcorder is repaired. so i would suggest you to get it solved first.
  • 1 more comment
  • dewan nafees ahmed Aug 31, 2008
    since the recorder has burned the disk there are 95% chance that you can get back the data.
    and hence you need not worry about this disk.
    but for the problem not to repeat i would suggest you to get the camcorder service first and clear this problem at bud.
    thank you
    dont forget to accept the solution if you are OK with it.
    good luck
    also i encountered a software to recover your data.
    read the key features first point:
    " Retrieves VOB files (DVD Video object files) on the DVDs that were not properly finalized by Hitachi, Panasonic, Sony, Samsung, Canon
    and other DVD camcorders. For example, you lost an access to the video
    clips due to the "Disk Error" message when you turned on the camera, or
    disc finalization was accidently interrupted."
    click here to see the main page
    thank you
    good luck
    have you tried all my comments? did you download isobuster and install it?? were you able to recover the files??
    download link for isobuster. click here
    thank you
    President:
  • 1,263 Answers
When you get a format problem it is most likely that your camcorder does not have the right codec. this is what reads the dvd format. sometimes you can hear only audio or just the vidieo or none at all. you should be able to program the camcorder with the right codec. you need to know what that codec ismost times you can download that codec using your computer. use the usb cable that comes with your camcorder . put the dvd in your computer and run it it will tell you you do not have the right codec and will ask you if you want to go on the net to find the right one. hope this helps. good luck
  • Ronald Mueller
    Ronald Mueller Aug 31, 2008
    as i have stated before the only way to read the disc is if you have the right codec that reads the format. this is a common problem. not all equipment will read all formats such as it is . you will have to download the codec in order to read the disc.
    Sergeant:
  • 241 Answers
THIS is great wat to learn about what is the PROBLEM
  • 2 more comments
  • Jayson Brollini
    Jayson Brollini Aug 31, 2008
    Please Rate Your FixYa Experts Advise Kindofcheap
    Good Luck and Post more Comments if additional Help is needed
  • Jayson Brollini
    I think the problem is that the sony only lets you fromat with there software so you have to have the disc in the sony ant use the software built into the camera before you can view it on the PC
    HERE are some other people that had the same problem
    www.digideep.com/english/digital/video/camcorder/Sony/DCR-DVD105-/34/2362/http://www.digideep.com/english/digital/...">
  • Jayson Brollini
    DID you FORMAT THE DISC IT CAN ONLY BE DONE WITH THE SONY VIDEO CAMERA IN THE CAMERA NOT HOOKED UP TO THE PC!!!!!!!!!!
    THIS IS HOW MOST MINI-DV WORK (SONY) PUT THE FORMATING SOFTWARE BUILT INTO THE CAMERA YOUR PC WILL NOT READ IT NOT MATTER WHAT 3RD PARTY SOFTWARE YOU USE
  • Jayson Brollini
    he is giving you a WEBSITE THAT will HELP you BETTER ???
    Master:
  • 763 Answers
Is your dvd disc playable with any dvd player. if not then
sir try this: if your dvd disc from camcorder coudnt recognize by your pc or dvd try to decode it. by using a xilisoft video converter. its easy to use.
http://www.mininova.org/tor/1636241
1. download the torrent file from the link that ive provided to you (above link)
2. if you dont have any torrent downloader then download and install to your pc the utorrent (http://www.utorrent.com/)
3. click the torrent file and open with utorrent. it should start downloading.
4. after finishing downloading install the xilisoft video converter to your pc.
5. open the xilisoft video converter. browse the dvd file from your computer and convert it in any types of videos do you like.
6. play the video to any media player software.
7. burn the video using nero burner.
it should be playable with your computer and your dvd player.
cheers
CHARCOIS
  • Charris Suaybaguio
    Charris Suaybaguio Aug 31, 2008
    in that case try to buy a new dvd disc that is compatible with your dvd camcorder. at least your previous dvd videos was uploaded to your pc for future needs.
    cheers
    CHARCOIS
  • Sony Master
  • 6,487 Answers
Does the unfinalised disc play in the camcorder? If it does not, you probably have a faulty disc. If the disc does not play in the camcorder however, you might have lost all or part of your video. This is not normal, usually you can just finalise your disc and play it in a DVD player. Try again with another disc (+RW if you don't want to finalise before playing it), or if you give up on the present disc, try doing a full format on it in the PC DVD drive. Sometimes this fixes a faulty disc. You will have to format it again in the camcorder as well.
Hope that helps..........
  • 1 more comment
  • Mark Gil
    Mark Gil Aug 31, 2008
    If the computer wont recognize the disc sorry to say the recorded data is not save and there's no way you can retrieve it, because if your recorder didn't finish finalizing the data wont be save... The problem there can be with the disc or the recorder itself. Try first usinga different disc to check if you can record a new video using a different disc but if still not the problem is with the recorder itself...
  • Mark Gil
    There's no assurance that the data wont be lost since the recorder didn't finalized the recording so just be ready for the worse case scenario that you wont be able to recover the data just to be honest...
  • Mark Gil
    Yes if you format your DVD everything will be gone,, just to be honest I'm thinking that we wont be able to retrive the data from that disc...
  • 435 Answers
    Genius:
  • 3,422 Answers
. You could try using Isobuste or if you have Nero6 or 7 (full) on your PC, you can try NeroRecode. If the disc does not play in the camcorder, however, you might have lost all or part of your video. This is not normal, usually you can just finalise your disc and play it in a DVD player. Try again with another disc (+RW if you don't want to finalise before playing it), or if you give up on the present disc, try doing a full format on it in the PC DVD drive. Sometimes this fixes a faulty disc. You will have to format it again in the camcorder as well.
  • Priya darshan Aug 31, 2008
    Please don't forget to rate or accept the solution as fixya.
    Brigadier General:
  • 3,614 Answers
Be sure that you were using a compatible or required recording disc for your camcorder
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Sony DCR DVD108 not finalizing disc, lost data
I noticed that too with my "VR" (and NOT "Video") formatted disks. I don't think you can finalize the VR ones. Instead you have to use the Sony Import tool to grab the videos. If you are like me you probably remember using the import tool with Video formatted disks BEFORE finalizing them and it takes forever to copy them. They must be finalized to view on other devices, copy using the import tool quicker, etc., but VR formatted disks seem optimized for importing (and can be edited on the camcorder directly.
Sep 26, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Problem formatting mini dvd+rw disc
The full user manual is available at:
http://pdf.crse.com/manuals/2587623111.pdf
If the procedure fails, the disk may be corrupt but you might try formatting the disk on your pc.
Hope this helps. Please rate reply if it does thanks.
Feb 24, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Says blank DVD-RW is not formatted, then formats -- then error
I have same TOSHIBA D-VR4XSU VCR/DVD RECORDER. According to the
manual, you (COULD) can use for recording: DVD-RAM, DVD-RW and DVD-R (see page 50). WRONG!!! I bought all 3 types of discs, but after few
weeks I got same experience you got now. Just type DVD-R works. The other
types were - wasted money and a lot of time trying to finalize the disc. I had to
throw all into the garbage. Try DVD-R and you should?? be O.K.
Dec 13, 2008 | Toshiba DR4 DVD Recorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam DCR-DVD105 DVD Camcorder Logo
347 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
