Question about Tissot T-Touch T33159851 Wrist Watch
Side button not working properly
One of the side buttons on my t touch only works if you press it in really hard - so that it hurts your finger. This never used to be the case. Is there a do it your self solution?
Try using Silicon instead of WD40.. cos WD40 will corrupt the rubber inside.
Posted on Sep 18, 2008
  • 2,071 Answers
Yes there is self solution,if you have WD 40 put it to the not working button . If you don't have WD 40 you can use also any kind of lubricating oil,take a needle soak it to oil,then put it to the button.Keep pushing the buon so the oil will penetrate down to the spring..
Hope this may help;
DON'T FORGET O RATE;
Posted on Aug 31, 2008
How to set alarm
Unless its some model I've never seen all timex watches have four side buttons. Some are really indented, almost hidden, and need to be pushed using a pen cap or something similar. The buttons are evenly spaced two on each side and can look like just hard plastic that will not move but they will if pressed right.
Mar 29, 2016 | Watches
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
"Perry" watch PHF006G 1008137001 M1229 Pressing Button "S1" does
Use a pen or pencil to press the S1 button. Even though the button is not flush with the edge of the watch, you still have to press it really hard to get the numbers to advance.
Dec 18, 2010 | Watches
I have a problem whit my Casio W94HF. It just stop working. It show the time but you can't push any button until I reinstall the battery help me please :)
usually when the watch still works but you cannot make or change any settings and you do not see any reaction or change when you push a button, then it means that one of the buttons is stuck (as if permanently pushed) and the watch will not react to any button until the stuck button is released. Inside the watch there are metal fingers (contact blades) that the buttons actually push, and sometimes one of these finger blades can get stuck even though the button has returned outward. try (with tweasers) to pull on each button to see if it will move outward and allow the watch to start functioning again. If not, then the watch must be opened,and with a fine pin-like probe, each metal finger blade must be tested for proper movement and position. Also, when a battery is replaced, occasionally the housing is not seated correctly when the "movement" is replaced in the housing (if it was removed in the first place), when the cover is back in place, if there is a plastic or metal bezel ring, maybe the ring is not seated correctly. goodluck, Macgivor
Jan 27, 2010 | Casio W94HF-3AV Wrist Watch
Juicy Couture 'Dalton' Watch i cant figure out how to open it to wear
Hope you've already got it figured out, but if not... you have to give it a good pull on the back of the link bracelet. Hold it with your fingers on the edges (sides) of the links and give a strong pull just to the side of the round button on the underside of the watch bracelet. One side comes off before the other, so if it doesn't click open, try the other side of the round button. It'll open half way, then do the same thing on the other side. You won't hurt it :) Beautiful watch. Mary
Dec 25, 2009 | Casio Watches
My tag heuer 2000 chronograph professional button hard to press
Yes it would seem unlikely that the dial would cause this problem. It is more likely to be the seal if the pusher seems hard to depress. Watches should be serviced every two to three years at which time pusher seals are usually replaced. Recommend you take it to a watchmaker for a service to maintain the watch properly.
Jul 27, 2009 | Watches
Tissot t-touch analog time is out of sync with digital time. How do I res-sync them?
This is the tried and tested solution from this very nice gentleman. Many thanks to him (Ha Bi):
  1. Press and hold on to the T button until it beeps
  2. Touch the middle of the screen to change digital display to unit selection
  3. Press and hold the T-button until "Synchronize" comes up in the digital display
  4. Use the + button and - button to align the hour and minute hand to 12:00.
  5. Click on the T-button again. Congrats, you're done!
  6. Enjoy~
Must see blog for all T-touch users
http://myhabi.blogspot.com/2008/10/tissot-t-touch-battery-change.html
Jun 04, 2009 | Tissot T-Touch T33759851
Athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Apr 30, 2009 | Watches
Tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Tissot T-Touch T33159851 Wrist Watch Logo
143 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Shehu Pro
Shehu Pro
Are you a Tissot Watch Expert? Answer questions, earn points and help others
