Question about Motorola Cell Phones
My phone will not stay on. It goes through it's stages, one minute it will stay on no problem, but then other times it just shuts off it will turn itself back on then turn right back off. what is up with that?
    Brigadier General:
  • 7,752 Answers
Try a new battery
Posted on Aug 31, 2008
After turned on the power, the unit shuts down immidietly
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
Mar 12, 2015 | Onkyo Ht-r510 5.1 Channel 100 Watt Av...
Samsung model dv5451 cooling light stays on
I am assuming when you turn it on, after couple of minutes goes off.
If you are on sensor drying and have no load or too little, then clothing might not touch the sensor enough (to show it is wet), and therefore microprocessor shuts unit down "thinking" everything is dry already. Try time dry.
Alternative: defective main board, sensor, wire harness.Call for service.
Dec 22, 2014 | Samsung Dryers
How do i keep the power on when it goes out in five seconds?
You can't. It's the systems' internal safety circuit shutting it down friend
Not an expert on those machines but it sounds like the power output stage is faulty and overheating causing a shutdown.
Needs new output stage or repair ?
Sep 14, 2014 | Boston Acoustics Avr7120 A/v Receiver
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
Nov 14, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes...
windshiled wipers will work on the intermittet stage for about 10-15 minutes then automatically goes to regular speed and will not shut off. When stop vehicle and shut engine off and let sit 15-20 minutes wipers will shut off. When needed again same thing will happen This is on a 2003 Chevrolwt express Va
Feb 09, 2010 | 2003 Chevrolet Express
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
My blackberry 8110 will not charge
this happened to me and i just shut the phone down took out the battery waited 3-4 mins put battery back in do not turn on phone but put it on charge and it should be ok.
Jan 25, 2009 | RIM BlackBerry Pearl 8100
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Cell Phones Logo
49 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
