Question about Sony Handycam DCR-TRV250 Digital Camcorder
Sm. triangle flashes
Record mode or vcr mode my cam flashes c31;23 and does not work I have tried reset still the same I've tried a new battery, nothing. Can tou assist
jerry
  • greenwilma Oct 27, 2008
    Same problem - small triangle flashes with the number 3123.
  • kristyfjenni Feb 25, 2009
    what if you can't even get it to open up and eject? Do you mean oil it while tape is still in and only the "door" is open - the mechanics are still closed?
I have found, that if you oilthe gears ( DO NOT OIL THE PLASTIC ROLLERS OR THE RECORDING HEAD, DO NOT USE WD40, USE AN ACTUAL OIL DRIPPER), and the hinge on the camera tape door, that it... So far has fixed my issue with the same problems and have been good for 6 months now. The camera would flach stuck tape, eject, and it would act as if it was stuck.
Posted on Feb 23, 2009
Samsung BN59-00603A remote - flashing VCR button
1) clean the contacts batteries very well with contact cleaners
2) retight the spring contacts batteries with pliers for better contacts.
3) open the remote and clean the KEYpad with c.cleaner from oxide, corrosion, dirty, dust, and proof. The syscom must emit I.R very clean for work.
4) if after you did the before mentioned step, go to the repair shop TV for fix it.
God bless you
Sep 16, 2012 | Televison & Video
My panasonic dvd/vcr combo displays the message DV D 2 in the display. Cnnot play DVD
Sounds like your remote code is different to what's in the unit's display (DVD 2). You can try to 'reset' the remote, by pressing (and holding) 2 and ENTER/OK buttons together for 5 - 10 seconds, then release. This should restore your remote function back to your unit. If it does not, replace the batteries with new ones, and try again.
The remote may require a 'reset' of its command mode (to match the unit) whenever the batteries are replaced.
I assume you can play DVD by pressing the PLAY button on the main unit.
Apr 28, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
No matter what mode I place the unit in..camera mode or playback mode...I get a yellow flashing triangle on the view screen. I can't record or do playback. Any idea what that yellow triangle represents? ...
I have the same unit and the problem your describing comes and goes from the power switch on mine. (wiggle it)
hope this helps (if it don't... get it fixed this is a cam that cant be replaced even broke they bring in 200 on ebay or did a few years ago )
Dec 14, 2010 | Sony Handycam CCD-TR517 Camcorder
I cannot record, in the corner where it says record, standby, it flashes the number C:31:40 I have a new TDK Hi 8 120 and it keeps flashing. Please help, thank cptaylor2000@yahoo.com
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
Jul 21, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR will not switch to program mode
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
May 14, 2009 | Mitsubishi HS-U545 VHS VCR
No picture in rec mode, cam switches off in 10sec
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
atdlee@netzero.com
Dec 24, 2007 | Canon XL1S Mini DV Digital Camcorder
Cannot playback recorded video
reel sensor is the problem of your camera... sometimes it is a poor connection of the sensor to the socket at the main board..clean the contact of the wiring using a pencil eraser and also check the pitch roller of the mechanical if it is install cause it might be loose at it post cause of the lock has been broken already...
Dec 06, 2007 | Sony Handycam CCD-TRV318 Camcorder
LG VHS GC480W - VCR 'safe mode'
What do you do if you lost your remote?
Is there some master reset availible?
Oct 26, 2007 | LG XBR446 DVD Recorder/VCR
Sony Handycam DCR-TRV250 Digital Camcorder Logo
78 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
