Question about Sony Hi8 Hi-8 Tape
Video Out Genius needed
When I connect my Sony TR350E to the TV there is no on either camera or playback.
When I disconnect just the Audio lead from the TV end, touch the lead up against the outside rim of the "in" audio and at the same time press the eject button- the picture is just beautiful. BUT it only lasts as long as the eject process. As soon as the "eject" motor stops whirring it is back to square 1. Similarly it only works if the audio lead is just touching the rim of the audio jack on the TV. If the audio lead is plugged in (or disconnected completely)- no picture.
The audio works fine on playback and camera through the TV when all leads are connected correctly.
  • tracey007 Aug 31, 2008
    When I connect my Sony TR350E to the TV there is no PICTURE on either camera or playback.- Correction to first sentence (Tracey007)
    Thanks for a quick reply VOTIT. I could not see the picture you posted. I don't get the feeling it is a loose connection because there is no intermitancy. It is almost as if touching the audio lead to the outside rim on the TV and hitting the eject button creates a circuit (earth?) that powers something to restore the picture output.
    The camera itself operates OK-ie record and playback tapes internally- just no picture to the TV without the above.
    What does the small round internal battery do? I have tested it and it appears to have no charge at all.
  • 2,071 Answers
You better check for loose connection or cold solder joint,Unfortunately, the solder connection alone is often used to make both the electronic as well as the mechanical connections. Solder is made up of 60% lead and 40% tin, so it can not be expected to do the mechanical job for long. Designing larger circuit board traces does help to increase the surface area as well as strengthen the pad and the trace leading to it. To minimize stress to the soldered connections, physically heavy components — as well as all frequently used switches and connectors — should first be mechanically secured to the PCB. Video Out Genius needed - joint.jpgFigure 1 has been magnified and enhanced to show four solder pads that have potentially cold joints. Counter-clockwise from lower right, the initial problem isn't so easy to spot, just a slightly "grey" or frosted joint, with each counter-clockwise joint getting progressively worse. This is what ultimately happens when a little pressure is applied over and over again via both mechanical stress and repeated heating and cooling cycles. This would be the case in any studio and especially on the road. Once in this state, the connector could easily be removed from the circuit board with little effort, without soldering. Sometimes the solder connection holds up, but the junction of the PCB trace and the PCB pad will break.
Posted on Aug 31, 2008
I have an old Sony CCD TR55E Handycam, I bought from new. Now I want to transfer my tapes to DVD, and seem to have lost sound output playing tapes to TV/Recorder. Tried running tape cleaner, no succes
What is your signal path? The question you need to answer is, "Where are you losing the audio?" Are you losing it between the tape and the playback head, or are you losing it in the cable, or are you losing it at the TV/Recorder?
Does the camera have an audio out into which you can plug ear buds to test the audio from the camera playback?
Nov 28, 2014 | Sony Cameras
I would like to know how to conect a Sony VHS to a TV? What leads go where etc. Thank you for your help.
you can connect the audio video out of your VHS to the audio video input of your tv. for that you need an audio video cable (have three RCA pin at the both side, one for video(yellow) and the other two (red and white) for audio.
connect the one end of the three rca cable to the VHS's audio video out according to the color code. and the other end to the tv's audio video input.
Then select the corresponding AV input in your tv using the remote.
Jan 25, 2011 | Sony SLV-N750 VHS/S-VHS playback VCR
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
Jan 06, 2011 | Philips 20PT633R 20" TV
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
There is no sound from speaker
Connect camcorder with TV with AV lead and confirm do you get playback sound in TV, if yes, then internal speaker in camcorder is bad, need to be replaced.
Aug 07, 2009 | Sony Video Cameras
Sony Video camcorder CCD-TR350E Blue tape ejection button
Same has happened to me... did you solve your problem? JT
Mar 25, 2009 | Sony Video Cameras
No sound on playback
The S-video cable carries picture only. You need to also hook up RCA audio cables from the camcorder to the TV
Dec 30, 2008 | Video Cameras
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
JVC dvl 9700 playback on tv is black & white
You can get the sound to play by hooking up an additional cord to the audio jacks - the same as you would do if you didn't use the s-video. I am still working on the b & w issue
Nov 27, 2007 | Video Cameras
Sony Hi8 Hi-8 Tape Logo
97 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
