Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Clicking sound and crumpled paper
I have a Xerox XD-100.
All of a sudden a "clicking" noise istarted recently after the machine is turned on and is warming up. This lasts about 10 seconds. The same noise is heard after pressing the "START" button. A paper jam symbol appears. Crumpled / accordioned paper is jammed beneath the fuser. Even after clearing the paper ----- the same noise and jam occur.
Result --- no copying possible.
What could be the problem?
Thank you
    President:
  • 2,072 Answers
Bad heat roll drive gear in the fuser. Very common problem.
Look up on google a business called "The Parts Drop". Ask for Britt, part is $13 or $14.
Posted on Aug 31, 2008
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
Xerox Phaser 7750DN 'Clicking' Noise - I have recently purchased this pre-loved printer and it has just started making a clicking noise during warm-up and when printing. I have run a Dispenser...
I suspect you have lumpy toner in the black cartridge and it will not turn properly. The sound is probably the impeller hitting hardended toner. Try another black toner but give it a good shake before you fit it and DONT empty the drum as you will lose the developer within it.
Hope that cures it. good luck
May 24, 2011 | Xerox Phaser 7750DN Laser Printer
Makes a loud clicking noise like a metronome
Sounds like the aftermath of a paper jam
The clicking is probebly either:
Feed transport roller out of line
Roller securing spring broken or dislodged
Opening up and investigating is the oonly option
Jan 13, 2011 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Paper Jam E2 error
On this model, the fuser assembley is mounted to the machine mounts, two of them inboard and outboard.
If the fuser gear is not cracked, this fuser is driven by the white small drive gear on the machine.
This rests close the drive gear. Sometimes you can hear a thumping noise which is coming from the gear skipping over the fuser gear.
This gear needs to be replaced a very involved service process.
Call Xerox for further repair if this is the case. Also behind this gear are many other gears that can cause this same problem. Very involved and time-extensive to repair even for a trained Xerox technition.
Aug 11, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Clicking noise
Sounds like a clutch has spun out to me...It's going to require tech.
Mar 13, 2009 | Brother MFC-8460N All-In-One Printer
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
ERROR E2
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox workcentre xd 100 paper gets jams just before intering fuser
On the XD 100 if it is jamming when it is just entering the fuser, check the gear on the end of the heat roll.
Those frequently crack and or flat out break off.
That gear is easily replaced and inexpensive. If you require information where to purchase one, let me know via a message here.
I checked and you can purchase that gear for $14 or less.
Nov 15, 2007 | Xerox Phaser 6100/BD Laser Printer
Paper in copier hangs up
it sounds like the heat roller gear has broken. open machine and look @ the heat section in the back you should see the gear broke.
Nov 04, 2007 | Xerox WorkCentre XD120f Copier
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
289 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
