Question about Maytag Neptune MAH5500B Front Load Washer
Power Washer Engine Locked Up
My husband said there was oil in the power washer; however, afer my son powerwashed the deck, the engine locked and there was no oil in the engine.
Can a power washer with a locked engine be fixed. Do you have any recommendations?
    Problem Solver:
  • 8 Answers
Odds are the engine is not easily repairable. The cylinder and piston rings are probably scored and will have to be replaced as well as the connecting rod and crankshaft and piston itself. possibly the valves and cam as well. A teardown and inspection would be necessary to determine the extent of damage
I would suggest finding an similar engine of equivalent power and replace the engine. Harbor Freight ( Harbor Freight ) is one source for replacement engines, there are others.
Posted on Dec 03, 2014
  • 639 Answers
Hi, My husband said there was... Answer This...
YOUR POWER WASH CAME UP UNDER NEPTUNE WASHERS????????????????????????
Posted on Sep 02, 2008
How is the carburator removed from a Homelite HL252300 powerwasher
You may have to remove the bolts that hold the engine to the cart and turn the engine sideways to clear the way to slide the carburetor off. It sucks but the manufacturer of the engine has no idea that the engines that are sold will be placed on a cart frame as a pressure washer.
If they did there would be a cut out to clear the carb for removal.
Aug 27, 2014 | Homelite Garden
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
What type of oil to use
for the motor you need to go by manufacturer's recommendation most pumps use 30w non-detergent oil with the dip stick screwed in
Oct 14, 2012 | Powerwasher 2400psi 2.0gpm Pw2420 Gas...
I have a Honda GC160 motor on a powerwasher. The engine stalls when I release the power wand handle, but if i keep the handle squeezed, it works but the engine sounds like it is laboring.
replace the unloader of your pump....find the model of the PUMP ...not the washer itself...the pump and find a parts list and then purchase and replace the unloader. That will fix your problem. Good luck
Aug 15, 2017 | Honda Garden
Engine on powerwasher starts but quits running after approx 10 seconds. Engine oil changed, oil is full & tried choke in various positions. Also has fresh fuel in tank. What else can I do
try cleaning the carb that ethanol plays havoc on these small engines if it is not a premix oil and gas unit add a little 2 cycle engine oil to the gas will keep the carbon builup to a minimum not to much it will gunk up your spark plug take the carb apart and clean it with carb cleaner or deisellet dry check your spark plug make sure it is clean and ok that is where I would start
Jun 27, 2011 | Craftsman 2700 PSI Briggs Stratton...
Motor will not turn over. Checked air filter compartment to find 2 oz. of oil and filter soaked.
Not sure if you mean engine will not turn at all (locked) or engine will not start. The engine may have been on its side causing this condition. Clean carb and filter of excess oil. Remove spark plug and clean cylinder and plug of oil that may have entered causing locked condition. Replace oil lost from crankcase. With spark plug removed and kill swith on off, pull rope to blow out oil and verify that motor will now turn. If it still does not turn could be lock rod to crank or faulty pump. If engine had very little or no oil in crank and was run, suspect locked crank, however if your engine has oil senser, this condition would have prevented engine from starting. If you mean that engine will not start, low oil senser most likely preventing start due to low oil. Good luck
Apr 04, 2011 | Honda 2500 PSI Gas Pressure Washer
I tried to start the pressure washer by lulling the cord, there was sharp popping noise, and the engine would not crank to start. It is a Honda K. washer. What went wrong? Pls advise, thanks.
Make sure your oil level is correct and not overfull. If ok, pull the sparkplug out. Then, pull the starter rope to see if the engine spins freely. If it does, pull it 4-5 more times to clear the cylinder of oil or gas. Put the plug back in and try it again.
However, if the rope fails to pull freely, you either have a locked engine or pump. You will have to seperate the pump from the engine to determine which is locked up.
Aug 02, 2010 | Honda Garden
I can't start my powerwasher. Where is the choke?
This Power washer has a 3.75 hp Briggs and Stratton Engine. It does not have a choke but does have a primer bulb. You must depress the primer bulb at least 3 times to start the engine. The primer bulb is on the side of the carb. It can be black or red. If your still unable to locate the primer bulb please provide your ENGINE model number and I will provide you a link to a diagram for the location of the primer bulb.
Thanks for using FixYa.
Kelly
May 29, 2010 | Briggs & Stratton Gas Pressure Washer...
Honda EXCELL 2600 Power Washer Pull locked
try to tap on the recoil cover to see if the rope returns,remove recoil cover if that doesnt work. What type engine and pump? The type of oil used in which the engine or the pump both should be listed in either the documentation you recieved at purchase or online.
Dec 22, 2009 | Honda Garden
Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Jun 21, 2009 | Karcher 2500 PSI Pressure Washer
Maytag Neptune MAH5500B Front Load Washer Logo
356 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
