Question about Sony Cyber-Shot DSC-F707 Digital Camera
DSC-F707 firmware How do I check to see what firmware I have on my Sony DSC-F707 it's not in the manual.Thanks
4 Suggested Answers
SOURCE: Sony digital dsc-f707 startup goes to "no memory stick"
The "no memory stick" error is likely caused by the ribbon cable connecting the memory stick bay. Instructions for how to fix this problem can be found on this web page. Following these instructrions, I had the problem on my F707 solved in less than 20 minutes.
Posted on Oct 16, 2008
SOURCE: Lcd screen on sony dsc f707 is green
I also have a dcs-f717 (far too aged now but still working) and went across a similar problem (LCD and finder green tainted). Just read these solutions which seemed awfully stupid but, damn it, just hit the body of the camera with my fist and now it's back to normal ! Thanks...
Posted on Sep 04, 2009
  • 28 Answers
SOURCE: can i use sony memory stick duo for sony cyber
The answer is yes as long as they are the same type memorystick.
Posted on Feb 10, 2010
  • 92728 Answers
SOURCE: sony cibershot dsc-f707 manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSC-F707&region_id=1
Posted on Feb 16, 2010
0 characters
1 Points
O flesh da minha camera sony dsc f707 nao esta funcionando gostaria de saber o problema sera que tem alguma configuracao
hi sony f707 and f717 have very common flash fpc(flexible printed circuit) torn due to flash defuse unit up/down many time. it just need replacement. Thanks and best regard!
May 24, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
Dear Sir I have sony camera dsc-f707 I am looking for the operating manual please help me Thanks
You can download the manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCF707
Mar 16, 2011 | Digital Cameras
Dsc f707 manual
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 17, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Can i use sony memory stick duo for sony cyber shoot DSC-F707
Feb 10, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
I insert a memory stick and it says "No memory Stick" although it will take and record pictures . Does anyone know where i can purchase a 128 Memory stick for the DSC -F707?
You should purchase online from some secure seller.
Like here, its Sandisk Homepage.
search for the compatible Card from the bottom right tab.
Also Note that DSC -F707 doesn't support more than 128-Mb cards.
If helpful, Kindly DO RATE!
Best Regards.
Jul 17, 2009 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony cibershot dsc-f707 manual
Apr 09, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
My DSC-F707 won't record images.
Sounds like the CCD has developed a fault. I had a F717 which had similar faults but this turned out to be a batch of faulty CCD's which I know the F707 shared. This maybe why Sony are not keen to get involved as it will cost them money. JVC had a similar problem with some of it's Camcorders using a similar CCD and they replaced them FOC even those well out of warranty. Keep trying with Sony and mention the CCD and serial number of the F707 and see if it is one of the faulty batch.
Oct 30, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
DSC-F707 camera cuts off after 10 second , just bought a new battery.
I also bought an aftermarket battery for my F707 on Ebay and got the same "for info...." message.
I contacted the seller and they sent me a new one and it worked, don't see a way around it.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Could be that the contacts on the camera are oxidised. Try cleaning the contacts with isopropyl alcohol and see if this helps. If not, it could indicate a circuitry problem. In this case, you'd probably be better off buying a new cam altogether!
Sep 28, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Sony Cyber-Shot DSC-F707 Digital Camera Logo
796 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
