Question about GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven
GE monogram double oven display getting extremely hot
Hi
I have a mongram stainless steel double oven and when I use the top oven the stainless display (where he knobs are) gets extremely hot. Any thoughts? We ran the self clean cycle today and the fan is still blowing but i cannot touch that panel because of the high temp.
  • Anonymous Mar 12, 2014
    making high pitch sound
  • 116 Answers
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Posted on Aug 31, 2008
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
What does F9 mean
Failure to clean code
I have two Monogram ovens but they are not adjacent to each other top and bottom but are separate in different areas of the counter. I did the self clean for both ovens for the first time and one oven had the F9 error code about 1 hour and 45 min into the clean and the other did not sound a code.
Jan 24, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
Heating up but display show 100 degrees and getting hot
Your thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Autolite will not stop sparking after range is lit
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 03, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
TOp Oven Light ..
if its a brand new unit (still in waranty) make the service call
Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge monogram single convection wall oven
There is usually a micro switch that is activated when the lock lever is in place - very likely this switch is still activated or has failed closed (defective) .
Aug 26, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ge double oven
I believe this is because it takes a while for your oven to cool down (the cleaning cycle uses a very high temperature to burn up the grease and food). The timer is how long it takes before it will be cool, at which time the oven will unlock.
Mar 17, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Monogram ZET3058SHSS Stainless Steel Electric Double Oven Logo
384 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
