Acer aspire 5610z start up problem
When I turn it on the computer, it will only show the first screen with the Acer logo and the blue bar on the bottom, that bar will get to about 60% before it shuts down. During this process the screen shows the option for Press F2 for setup. When I go to do that, the option is replaced with "Please Wait..." and will do nothing further. Nothing happens if I press Alt and F10 either. Any ideas ?
  • wpcalvert Aug 31, 2008
    Thanks for your reply but the notebook doesn't get as far as safe mode. It shuts down after about 5 seconds.
May be some of your windows system file is got currupt, u can try by starting ur system in safe-mode. if it starts in safe-mode restore the system to privious date
start>> programmes>> accessories>>system tools>>system restore
Posted on Aug 31, 2008
My Acer aspire turns on shows windows logo then goes to black screen, what can I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Jul 18, 2015 | Acer Computers & Internet
Hi, I have an Acer Aspire 5610z and, when I turned on the Acer Logo nor bios post shows up. The entire display remains dark. If i press F8 or scape, nothing happens and no bio sound but, power light comes...
Dear User,
Remove the battery and connect the adapter and check if display comes otherwise the issue seems to be with system board.
Regards,
Tech_Comp
Feb 23, 2011 | Acer Computers & Internet
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
Acer aspire one
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
Mar 17, 2010 | Acer Aspire One PC Notebook
MY ACER 5610Z LAPTOP STARTS UP BUT WONT LOAD WINDOWS
WIth the limited fault description its a guess at best. you probably have a corrupted driver or hard disk fault. If you can try a replacement hard drive and reload OS you should get progress.
Sep 29, 2009 | Acer Aspire 5610-4648 Notebook
My acer travelmate will not boot up, please help
hard disk error, insert operating system disks and run a repair or a complete clean installation.
Mar 02, 2009 | Acer Aspire 4315 Notebook
My Acer Aspire 5610z laptop drivers are corrupt
Hi Garvoyee, try this program which will help repair your windows registry& blue screens;
http://www.zaperrors.com/?t202id=911719&t202kw=code%2039&gclid=CP2Y1_3cw5gCFQpuGgodSBwR0g
Below is Acer link: (Drivers for both XP & Vista) There is no 5610z, only Aspire 5610.
http://support.acer-euro.com/drivers/notebook/as_5610.html
Feb 03, 2009 | Acer Computers & Internet
ACER Aspire One screen black out after start up.
OK, Not sure about the Aspire One, But I had the same problem with the Aspire 5610Z.
I simply found the Bios battery and with a small screw driver, created a short circuit of the bios by touching the two leads (just for a couple seconds) from the Bios Battery to the Motherboard. And It Works Fine Now!
Be sure to Disconnect all power from the laptop, and remove the Battery before doing this.
You can do as I did and download a free manual of your laptop which shows you where the bios battery is located.
Good Luck ô¿ô
Dec 27, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5100 will not start right
It seems your hard drive has corupted.
This sucks, all you have to do is push ALT F10 and then go through the reseting menu, you will loose everything on there though except the original data.
Jun 24, 2008 | Acer Aspire 5100-5033 Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
