Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Some games won't play - it reports that the disc is not in the game drive
When try to play a game, with disc in the drive, it reports the disc as absent (microsoft error esage)
  • 29 Answers
Make sure that the disk dosent have any scratches on it. does a regular cd play in the drive? if so try using a laser disk cleaner. you should do this after every 10 hours of play
Posted on Oct 19, 2008
My wii won't play any games, I just get an error message
Well it might be that the disc drive is bad then or the reading laser is weak too.
Sep 16, 2012 | Nintendo Wii Console
Wont play game disc
What disc are you putting in?
Mar 19, 2008 | Microsoft Xbox 360 Console
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Hi my name is chris and I have a game that I bought last year and i am 11 years old. when i got this there was no scratches but when my family was moving and i was at school at that time my brothers were...
It is possible that your game is scratched up enough that you can't play it directly on your xbox 360... BUT you might still be able to play it is you can save it to your Xbox 360 hard drive. You might need to try it a few times to get it to read and work but try following these instructions for installing the game from your CD directly onto your Hard drive. You will still need to have the CD in your Xbox 360 to play but it will be reading from your hard drive if you can install it. Good luck:
To install a game on your hard drive loadTOCNode(2, 'moreinformation');
  1. Insert the game disc into the disc drive.
    Note After you insert the disc, the default option is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
  2. From the Xbox Dashboard, go to My Xbox.
  3. Select the game you want to install.
  4. Press the Y button on your controller.
  5. Select Install to Hard Drive.
  6. A progress indicator appears while your game is being installed on your hard drive.
Note Installing an Xbox 360 game might take 12 minutes.
To play a game from your hard drive loadTOCNode(2, 'moreinformation');
  3. Select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
To delete a single game from your hard drive loadTOCNode(2, 'moreinformation');
  1. Insert the game disc for the game you want to delete from your hard drive.
  2. Go to My Xbox, and then select the game you want to delete.
  3. Press the Y button on your controller.
  4. Select Delete from Hard Drive.
To delete multiple games from your hard drive loadTOCNode(2, 'moreinformation');
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Select Hard Drive.
  4. Select Games.
  5. Select the game you want to delete.
  6. Select Delete.
To clear space on your hard drive loadTOCNode(2, 'moreinformation'); If there is insufficient space on your Xbox 360 hard drive, you will receive the following message:
Not enough space to install this game. It needs [space needed] free space to install. Do you want to clear space? (YES/NO) Click YES to view a list of games that you can delete. After you clear enough space on your hard drive, you can install the new game.
Jul 20, 2011 | Video Game Consoles & Games
When putting in Forza Motorsport 3 the console makes a lound noise, like the fan is on overtime when reading disc a lot louder than other games. Tried other games after and just low hum. Is it the...
Likely that for some reason the Xbox is having a hard time reading the disc and it is spinning the drive trying to search for files on the disk. If you aren't having the same issue with other games then recommend to resolve this issue then simply install the game onto your hard drive and the game will then only need to be accessed for verification only and the game will be played off your hard drive and not your disk drive. Here are the instructions for insalling a game to your hard drive:
Install Xbox 360 games on your hard drive from a game disc Note Installing an Xbox 360 game on a hard drive requires between 4 and 8 gigabytes (GB) of free disc space.
    Note After you insert the disc, the default option is to automatically start the game. If the game starts, exit the game, and return to the Xbox Dashboard.
  4. Press Y on your controller.
Notes
  • Installing an Xbox 360 game might take several minutes.
  • Multidisc game? Install each disc to your hard drive.
Play a game from your hard drive
  2. Go to My Xbox, and select the name of the game you want to play.
Jul 18, 2011 | Microsoft Xbox 360 Console
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
5 minutes playing online keep giving me error message that the disk is dirty. i know it's not i played the same cd to another xbox console it's fine. what should i do or what's the problem...
Hi chrisastig
try to save the game you are playing to the hard drive so as to play from hard drive & not from the disk ! this is assuming you have enuf room on ur hard drive to copy the game to ??
You will still need to put the game in (even when playing from hard drive) but i find if its a game you play a lot its well worth doing as it saves on the disc drive/disc spinning whilst playing :-)
saves on overall usage of the xbox too !
If its ok reading the disc for the first 5 mins of usage it should be ok to copy to the hard drive to play from.
If there is a fault with the disc itself it will tell you when you try to copy it to the hard drive & if this is the case (& its a game you like/play a lot??) then try to borrow a copy just to put on ur hard drive only & use ur damaged disc as the 'required even if playing from hard drive' notification to the xbox that you do own the original copy !
Damaged discs are usually ok for 'playing from hard drive' as the information the xbox requires is very little but enuf for it to allow you to play the game (from the hard drive)
You will find it a lot quieter whilst playing anyway ! i think so !
hope this helps :-)
please remember thumbs up :-)
p.s. refer to ur xbox user manual or drop me a mail if you have any problems doing any of the above ??
Feb 14, 2010 | Microsoft Xbox 360 Console
Sims to double deluxe eror report!!!!!!
You have to have the disc in your cd/dvd drive to play the game. the game will not play without the disc. If you have any expansion packs installed you need to use the latest expansion disc. For instance, I have Free Time but not Apartment Life so I must have the Free Time disc in the drive to play the Sims 2, not the Sims 2 disc.
Jan 27, 2010 | EA - Electronic Arts The Sims Double...
X-box 360 won't read discs
sounds like the reader lens has burnt out on it .is your xbox stood upright ? seem to hear the lenses burn out alot faster if the consol is upright as opposed to being led down, you can buy the parts from ebay or other computer shops , or send it back to microsoft to repair , you are able to lay downloaded games as they play off of the hard drive memory , where as the disc games obviously read off of the disc when the laser gets tired they work intermitantly then eventually stop all together.
hope this is of help to you
kind regards
bert31000
Mar 19, 2009 | Microsoft Xbox 360 Console
Xbox360 defective and ruined games.brand new console and games.
Hello.
Xbox DVD-Drive's often scratch circles into your discs and some even got malfunctioning lasers that will burn rings into games.
To prevent the circular scratched from happening avoid moving your console at any time while it is running however it often also occurs just in regular use especially for older consoles with Hitachi or Samsung drives.
As far as I know Microsoft replaces discs that were clearly damaged by a console free of charge, at least here in Europe they do.
Try calling Xbox Customer Support and ask for a replacement it is worth a try for sure even if they shouldnt replace it they will at least give you a 1-month subscription for Xbox LIVE in exchange.
If you can get the console replaced as well depends on the support person you are talking to but usually they charge you for that if you want to fix the drive yourself, open up a PC drive and take the foam pads outs and install them in the 360 drive this will prevent the discs from getting scratched they just didnt use these pads in the Xbox for some reason which led to these problems...
I hope this helps and Good luck!
Kind regards,
Wilhelm@Xboxexperts.com
Dec 26, 2008 | Microsoft Xbox 360 Console
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
46 people viewed this question
Alun Cox
