Question about Dryers
We have an indesit is70cs. The empty water light will not go out (even though the water drawer is empty). So this means we are not getting any heat to the washing. We have cleaned out the filter and condenser filter but still no joy. Please help xxx
    President:
  • 1,462 Answers
Empty light is operated by a microswitch in the box where the pump is and fault can be:
pump faulty
microswitch stuck in up position.
to access, remove small panel on rhs at back and box will come into view
Posted on Aug 31, 2008
Water light on but no water in, and will not heat up.
do you have this?
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
Jul 11, 2012 | Indesit IS70C Electric Dryer
Empty light on but no water in
I think switch might be gone or stuck
The light on the water drawer of my IS70C dryer is staying on and the dryer isnt drying.
Thank you for the direct question but unfortunately we don't work on Indesit units and have no documentation on them, so I am unable to help you.
Sep 03, 2011 | Indesit IS70C Electric Dryer
I have Indesit IS70C dryer and all of a sudden it's not getting hot when switched on and the water container is empty..water is not draining from the clothes to the container and machine is not getting...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101.//.';';]\\
Jul 25, 2011 | Indesit IS70C Electric Dryer
Reset on indesit dryers not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 01, 2010 | Indesit IS70C Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
Hi,my indesit IS70C tumble drier works but does not heat up.\possible causes please.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer isnt working correctly. The light which tells you to empty the water is staying on the water draw isn't filling up with water and it does not get any heat. ( I Know I Am Blond...
problem is probably the pump that sends water up to the container. take small panel off back and pump and water container is exposed. power the pump independently and see if it works
Aug 05, 2008 | Dryers
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Indesit IS70c condenser dryer
CHECK PUMP AND FLOAT AT REAR OF DRYER EITHER PUMP IS BLOCKED OR PIPE FROM PUMP BUT MAKE SURE THE DRYER IS UNPLUGGED WATER AND ELECTRIC DO NOT MIX,
IF YOU ARE UNSURE WHERE TH PUMP IS GET A QUALIFIED ENGINEER
Dec 25, 2007 | Dryers
Dryers Logo
339 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
