Question about Brother MFC 420CN All-In-One InkJet Printer
Connection to computer
I need to know how to connect the printer to the computer. I do not have the manual
    President:
  • 1,114 Answers
Hi - You can download the manual from the link underlined in blue below:
MFC-420CN
Other info here.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 31, 2008
    Novelist:
  • 158 Answers
Go to www.brother.com. Click on the SOLUTIONS CENTER, where you can download the operators guide for your model.
How do you print to printer?
Hello, Terry -
You need to have the latest driver for your printer installed on your computer.
Plus, you need to have your printer connected to your computer, either by direct connection with a cable, or via WiFi connection.
The computer must be powered up and the printer power must be on. There must be adequate ink in the printer, and paper. Plus, if the connection is via WiFi, the computer must be connected to the Internet.
Once you have chosen the document, image, whatever to print from your computer, you should be able to follow the steps to print. I don't use a MacIntosh, so if you have a Mac, I cannot provide those steps for you. If you use Windows, once the document/whatever you wish to print is selected, click or tap on FILE (upper left of the window), click or tap on PRINT, and follow the on-screen steps.
I hope you have the instruction manual for your computer so you can read through it and follow the instructions for printing.
If you do not have the instruction manual for your computer, if you add the make and model of the printer in the Comment section, I may be able to locate the manual for you online.
Best wishes.
Feb 22, 2018 | PRINTER Office Equipment & Supplies
Dell user manual
If its a newer computer its a usb cable into one of the many usb ports
Google USB connection (switch to image)
if it's an older computer it's a serial connection
Google Serial cable (image)
if it'd real old it's a parallel connection
Google parallelcable (image)
Sep 07, 2014 | Dell Computers & Internet
Connecting hp photo smart 7350 printer to northgate computer
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Jan 23, 2013 | Northgate Computers & Internet
It's Kodak ESP 7 all in one printer I need it to connect to computer and it's even directly connected and it still wont
etHard to see on your video, but the blue cable - is that the one you are using to connect your printer to your computer? That looks very much like a network cable. Is that correct?
To connect the printer directly, you have to use a USB cable. If you use an Ethernet cable, the printer has to be plugged into your router or switch, or it will not get an IP address. Check the user guide here: http://resources.kodak.com/support/pdf/en/manuals/AiOPrinters/ESP7/1K3397_SETUP_BOOKLET_ESP7_en.pdf
What does your setup at home look like? - Router, Computer (OS), wired/wireless?
If you need more help, let me know and please provide some details.
Jan 03, 2013 | Office Equipment & Supplies
Hi Kandi, My name is Tom. First, I need to know
the cable should have a usb at one end and a mini usb at the other
what is in the ram card will be sufficient as the pc downloads any printing into the card in the printer
follow the user manual or download that manual from the manufactures web page
basic connecting is to turn the printer off, connect the cable then turn the printer on ( make sure that there is a power supply for the printer)
go to the control panel and click on add a printer
if you have a disc install it when requested and let the installer wizard to the job
Jun 21, 2017 | Fargo Pro L ID Thermal Printer
I just changed from DSL to FIOS, and now my fax/printer/scanner (all-in-one) will not print. I have an ethernet cable connected from the printer to the FIOS router, and who knows where to plug in the phone...
First, the phone connection to the fax simply needs to come from a regular phone jack. You will need to have a regular telephone number in order for it to work. As I understand it, FIOS is a fiber network, which means everything is comming to you via the internet. Faxing does not work over internet telephony
On to your printer.
If you had connected the printer through ethernet before, the IP your computer thinks the printer is on is most likely no longer valid. You will need to either reinstall your printer (easiest solution - recommended), or re-connect to it manually (requires much greater skill and knowledge).
I cannot assist you with re-connecting it manually, so your best bet is to simply re-install the printer.
Good Luck!
Aug 06, 2009 | Office Equipment & Supplies
Connecting USB cannon mp610 printer to computer
You need USB A-B cable and use the USB jack lying on the back-right corner of the printer (not the front one - that is for connecting cameras).
Sep 02, 2008 | Zebra LP 2844 Thermal Printer
Connecting my new PIXMA MX700 to my computer
Please read your owners manual.
It's very simple to connect a printer, and ever simpler to read the part of the manual that tells you how.
Perhaps you should get a friend to help you. If I say "Power Cord" and "USB Cable" will you know the difference? If not, I probably couldn't explain it to you through type.
If you think you could tell them apart, then do this:
1. Make sure you have a USB cable. Most printers don't come with a cable to connect to a computer. If yours did, you'll have two cables in the box. The USB and the Power cables.
If you don't have a USB cable, you'll have to go buy one.
2. Put the CD into your CD ROM drive, follow the instructions. When the computer tells you to, plug your USB cable into the back of the printer and the computer. Plug the power into the printer. Turn the printer ON.
The computer should detect the printer. Follow the instructions on the computer screen.
That should be all there is to it.
Dec 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP1020 / USR7500 error connection
That model is a "Host-based" language printer. You should use some other printer which supports PCL ...
Oct 26, 2007 | U.S. Robotics USR7500A Print Server
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
